How do I connect the smart watch with my cell phone with blutooth?
SOURCE: help. bluetooth!
you can master reset the phone and if that does not help you may need to reflash the phone, so take it to a mobile service center close to you to have that done or got to topsony.com
SOURCE: Help!!!!
check on first place of ur phone already sets to visible for everybody then activate the both bluetooth
and see if pc can detect it
tell me more info so i can help u
plz rate this post as good as u can
SOURCE: Verizon V9M bluetooth cell phone does not fully work with car
I have the same problem and thus far my research shows that the V9M is NOT a supported phone on the 2010 E class. You can store manually numbers into the car's system.
Sony Ericsson phones have built-in Bluetooth capabilities which allow them to be connected to a computer or a Bluetooth-enabled accessory such as a headset or speakerphone without using wires. Since Bluetooth does take some power to operate, most Sony phones default to having the Bluetooth powered off to conserve battery power. You can power on the Bluetooth on your phone fairly quickly.
Step 1
Press the "Menu" button on your phone and then select "Settings" from the available options.
Step 2
Select "Connectivity" from the Settings menu, and then select "Bluetooth" from the available options.
Step 3
Select "Turn On" from the Bluetooth menu to power on the Bluetooth on your phone. If you only have a "Power Off" option, then your Bluetooth is already powered on.
