SOURCE: lg lhd65el dehumidifier icing up
This will need to be serviced. LG has a 5 year warranty on these models. They usually will tell you of a service center nearby which will service it free of charge since it is under warranty. If you do not live near a service center they may ship you a replacement and you send your old dehumidifier back to them. Make sure you have your reciept when you contact them so they can verify it is 2 years old.
SOURCE: Ice on dehumidifier
A dehumidifier works by cooling the metal pipes on the back of the unit to create condensation (water vapor in the air). This then drips into the collector bucket. If the unit runs too long the cooling tubes can get too cold and freeze the condesing water vapor. Unplug the dehumidifier and let the ice melt, when u turn it back on, turn it down, it may be up too high. If you find this solution helpful please rate it.
Thanks - Tech101
SOURCE: back of dehumidifier forms ice
I have a Hampton Bay HB50 with the same problem. I replaced the defrost control switch that connects to the compressor inlet line. The part # is 112900550001 and it was about $50.00
SOURCE: Delonghi dh400p dehumidifier error e1 with ice
was the filter dirty that will do it let it defrost and put it back on
SOURCE: Dehumidifier not removing moisture
could have overheated the compressor if the filter was really dirty and blown it
