Question about Sennheiser Audio Players & Recorders
How do I connect RS 120 headphones to Vizio M320VT TV?
Posted by dave leclair on
zeceten
    Sergeant:
  • 399 Answers
Probably yes, connecting the RS transmitter to the composite audio output jacks (L/R) on the back of the Vizio TV.
Posted on Dec 26, 2014
I have Vizio M320VT TV and no audio out. where do I plug in my RS 120 headphones?
I hope this may help you.. https://www.youtube.com/watch?v=jWx6rX434CM visual is always my best teacher.. if not then refer to the manual http://cdn.vizio.com/documents/downloads/hdtv/M320VT/615M320VT%20User%20Manual.pdf
Dec 26, 2014 | Sennheiser Audio Players & Recorders
Do I connect them to dish or TV?
The television audio out is the way to connect them. If you connect them to the cable box you may have audio lag.
Nov 01, 2014 | Sennheiser RS 120 Consumer Headphones
Works with Direct TV but will not work with Net Flexs. I have a Sansung 2010 smart TV with Samsung sound bar
If it works with one, it would work with both unless you have it hooked up wrong or are not using the proper settings.
Jul 13, 2014 | Sennheiser RS 120 Consumer Headphones
Sennheiser RS 120 headphones won't work, only hear static
Adjust the tuning wheel on the side of the headphones so it picks it up.
Mar 20, 2014 | Sennheiser RS 120 Consumer Headphones
We have purchased sennheiser RS 120 wireless headphones but find our LG tv model 32LS3450 - TA does not have audio out, is there a solution?
Your TV should have Audio out somewhere, even if its digital audio out, you could output to a receiver and then hook your headphones to the receiver.
Oct 13, 2013 | Sennheiser RS 120 Consumer Headphones
THE HEADPHONES ARE CHARGED BUT WONT WORK. THERE IS A CONTIOUSE GREEN LIGHT WHICH IS ON. ON THE HEADPHONES.
Wireless? Are they connecting with the base? Try unplugging the base to reconnect. What are they connecting to? TV? computer? What?
Nov 10, 2012 | Sennheiser RS 120 Consumer Headphones
Audio from tv is not restored by turning off power on headphones
It sounds as if you are plugging the base into a standard headphone jack located on the Television set.
RCA Headphone jacks (incl mini) automatically stop the sound output to the main speakers on almost every set I have seen.. or home stereo.. etc etc
In other words you can take a standard RCA jack.. with nothing connected to it.. plug it in while the music or sound is coming out the main speaker.. and it will cut off the output to those speakers..
If you set has audio outputs on the back.. preferably Fixed Audio Out .. you will need to connect your base unit to those.. turn your set volume to 0 and adjust the headset volume using the control on the right ear-cup.
If you have variable audio out.. you will need to go into your TV sets setup menu.. turn off the speaker.. and turn up the set until you achieve a signal and decent volume through the headset.
If you are missing these connections.. your current “work around” is your only solution.
Best of luck
Dec 31, 2008 | Sennheiser RS 120 Consumer Headphones
RS 130 not working?
I am having the same problem...i tried resetting it as well...no luck
Jan 13, 2008 | Sennheiser RS130 Headset
270 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Geoff
 Grubhead
Grubhead
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
