Question about RC Thunder Tumbler Rc Car
My son got a thunder tumbler for Christmas but the car will not turn off, the light remains on. What is wrong?
We would have to take the batteries out after every use to turn it off. That cannot be right.
Posted by Pam McCoy on
CU RO
    New Friend:
Probably different frequency remote relative to car, same deal with my sons......car and remotes need to be on the same frequency....either 27 or 49
Posted on Jan 16, 2016
2 Related Answers
Anonymous
  • 11 Answers
SOURCE: My grandchild got a Thunder Tumbler for
Make sure your remote is not cracked in tha back because it will not work & make sure tha batteries are put in all tha way
Posted on Dec 29, 2009
Anonymous
  • 11 Answers
SOURCE: our thunder tumbler only goes forward on back two
there is no problem that is tha way it is sopoesed to be
Right turn signals work but left signals don't work
Front right and rear right are on a different circuit than the left front an left rear. Locate the Flasher control module behind dash. With key in RUN position check for pulsing battery voltage on the Green/white wire coming out of the flasher control module electrical connector. If no battery voltage, check for battery voltage coming into the flasher from the turn signal switch on the white/red wire. Left turn input is on the white/black wire. If not battery voltage on white/red, but voltage on white/black when turning left, then the turn signal switch is bad
Dec 05, 2017 | 2002 Mazda Protege
Tip
Trailer Wiring Cheat Sheet
Hello all,
For those of you that have or occasionally borrow trailers and look at the wiring plugs with disdain (I mean face it they don't make sense, grd is white, +12vdc is black, etc), this is for you.
Plug Types/Application
7 Way - RV Trailers, Horse and Utility Trailers
6 Way - Horse, Stock and Utility
4 Way - Utility Trailers
Columns are: Color, Function, Mark on the plug.
Seven wire Trailer plugs:
Horse, stock or utility trailers:
White = Ground - 1
Blue = Electric Brakes - 2
Brown = Tail and clearance lights - 3
Black = Battery, aux power - 4
Yellow = Left turn/Brake - 5
Green = Right turn Brake - 6
Orange or Purple (not both) = Auxilliary or Reverse - 7
Recreational Vehicle:
White = Ground - 1
Green = Tail and clearance lights - 3
Red = Left turn/Brake - 5
Brown = Right turn Brake - 6
Yellow = Auxilliary or Reverse - 7
Six wire trailer plugs:
White = Ground - GD
Yellow = Left turn/Brake -LT
Green = Right turn Brake -RT
Brown = Tail and clearance lights - TM
Red or Black (not both) = Battery, aux power - A
Blue = Electric Brakes - S
Recreational Vehicle: (color, use, plug mark)
White = Ground - GD
Brown = Right turn Brake - RT
Green = Tail and clearance lights -TM
Black = Battery, aux power - A
Red = Left turn/Brake - LT
Four wire plugs:
White = Ground
Ground should be 10ga.
Others 14 ga
Best regards
Mike
on Sep 23, 2009 | 1998 Ford Explorer
Tip
Hello all,
White = Ground - 1
White = Ground - 1
White = Ground - GD
White = Ground - GD
Yellow = Not used -
Four wire plugs:
White = Ground
Others 14 ga
Best regards
Mike
on Sep 19, 2009 | 1987 Jeep Wrangler
How to turn on Model No. 3000001019 Coleman headlamp. I got the batteries in but it does not go on. How do I turn it on?
Make SURE you have the batteries in the right way. If you have a battery turned around it won't work, plus you will likely bend the spring inside and then be unable to get the battery in the right way.
Dec 25, 2010 | Coleman 3AAA LED Headlamp
Tip
Trailer Wiring Standards (Color Codes/Plug Marks)
Hello all,
For those of you that have or occasionally borrow trailers and look at the wiring plugs with disdain (I mean face it they don't make sense, ground is white, +12vdc is black, etc), this is for you.
This will show you how to wire trailers with seven, six and four pin connectors
Seven wire Trailer plugs (Large trailers with a battery and electric brakes):
White = Ground - 1
White = Ground - 1
White = Ground - GD
White = Ground - GD
Yellow = Not used -
Four wire plugs:
White = Ground
Others 14 ga
Best regards
Mike
on Sep 09, 2009 | 2004 Dodge Ram 2500
My camera turn right off when i tirn it on
suspect battery is low.
suspect battery has not charged properly in charger.
suspect battery may be defective.
suspect camera is defective.
i would ask a specialist at a camera store to check this.
Nov 15, 2009 | Sanyo VPC-S1080 Digital Camera
Wiring towbar for t25 volkswagen
Hi Paul,
This should help,
Columns are Color, Function, Mark on the plug.
White = Ground - 1
White = Ground - 1
White = Ground - GD
White = Ground - GD
Four wire plugs:
White = Ground
Others 14 ga
Best regards
Mike
Sep 15, 2009 | 1986 Volkswagen Wagon Camper
When I turn on the battery it would turn right
buy a new battery as you've cooked that 1.
Feb 09, 2018 | Quantum Cameras
CAMERA WON'T TAKE PICTURES?
i don't know what age the camera is, did you try full batteries , normally it shouldn't do this it must have a defect if the batteries are not the problem..
perhaps contact the dealer see what is wrong with it..
Jan 03, 2008 | Olympus FE-180 Digital Camera
RC Thunder Tumbler Rc Car Logo
375 people viewed this question
Top RC Toys Experts
Tom Chichester
Marvin
Marvin
Vernon Taylor
Are you a RC Toy Expert? Answer questions, earn points and help others
