Question about Sharp DK-A10BK Shelf System
Need a manual
Need manual for DK-A1 music system for iPod.
Posted by Sharonl on
Anonymous
    Scholar:
  • 31 Answers
Hi There Sharonl,
Try the following URL:-
http://www.user-manuals.com/my_files.php
Cheers from YUBEUT.
Posted on Nov 16, 2007
CAN AN IPHONE 6 PLAY THROUGH MY ONKYO HT-S5100 AUDIO SYSTEM THAT HAS A DEDICATED IPOD DOCK
The included i-Pod dock is the DS-A1 and it is not compatible with any iPhone. It's compatible with the third (select versions) through fifth generation iPods. It can also work with the IPod nano (first and second generation), iPod mini and iPod Photo. On the Crutchfield product page, http://www.crutchfield.com/S-GQfUerwopyn/p_580DSA1/Onkyo-DS-A1.html, look at the Details tab for a complete list of compatible devices.
You can find this list also in the HT-S5100 manual (page 65) and the DS-A1 manual (page 6). The direct links to both of these manuals are http://filedepot.onkyousa.com/Files/own_manuals/HT-S5100_En_A.pdf and http://filedepot.onkyousa.com/Files/own_manuals/DSA1.pdf .
I wish that I had better news for you.
May 14, 2016 | Onkyo ht-s5100 - 7.1 Home Entertainment...
How do I delete music from ipod?
If Itunes failed, I would suggest you plug the ipod to your computer and manually delete the music files. If you running Windows OS let me know if you need steps on how to access your phone from Pc.or go to http://chasms.com/ for any system help
Jan 02, 2015 | Apple iPod touch
Playing ipod on samsung MME460D
I've just been struck down with this too on my newly purchased MM-E460D. I think I've worked it out, its just a poor description and manual. iPod mode" means choose the music off the iPod via a connected TV whereas "Remote iPod" is choose the music off the iPod via the Samsung remote and also directly from the iPod interface. I've been there for days trying to get "iPod mode" to work via the iPod interface.
Oct 01, 2012 | Samsung HT-Z310T Theater System
When I connect my usb to my ipod it just says "reading"..
ANSWER:
The USB is not going to work with your iPod. It is intended to be used with a flash drive or external hard drive with a folder structure containing either .mp3 or .wma files.
REASON: The way the USB works on the system is that it reads all the files and folders on the entire device and will say "reading" until it reads all the files and folders. This should only take a few seconds but if there is tons of files it may take longer.
Main problem: An iPod contains much more than just music files and folders - it contains an entire operating system. Worse, the operating system which the iPod uses is protected, keeping other devices except for iTunes from reading the music files.
SOLUTION:
You will need to use a flash drive or external hard drive with your USB. This device can only contain music, and the music must be organized into folders. Your iPod will not work. However, you can use Auxiliary input using a cable which both ends are 1/4" headphone jacks, one end going to the iPod and other plugged into your stereo.
Good Luck!
- Chris Proia
p.s. Here is the User Manual for your XDM6350 : http://www.dualav.com/support/manuals/xdm6350.pdf
Apr 09, 2011 | Dual Electronics XDM6350 Car CD/ MP3...
I've never used my new ipod Nano. How do I load songs and albums from itunes
You'll need iTunes - the software that Apple has developed to do this sort of thing. Get it at:
http://www.apple.com/itunes/download/
Once you've downloaded and installed that, open it up.
Now, you have two options as to how you're going to "sync" your iPod. ("Sync" means synchronisation - loading the music onto your iPod). There are two ways, automatically and manually.
Automatically is where you have your music library on your computer. When you plug in your iPod, the computer checks the music library on your iPod and does what it has to do to make the iPod's music library identical to the one on the computer, whether this means deleting things off the iPod or copying music over. This is great if you just want to manage one set of music. You just manage it on your computer, then when you plug your iPod in you don't have to worry about it - the computer just does it. This is the simpler option.
However, this means you need to keep a copy of all your music on your computer - and you can't plug your iPod into any other computer. That's why you can manually manage your iPod. When you manually manage your iPod you drag and drop the music you want on to it - the computer DOESN'T do it automatically. This is good if you don't have much room on your computer, so you can't keep a copy of the music - or if you want to get music off more than one computer.
Plug your iPod in to the USB port of your computer. Follow any prompts that come up you should be presented with a screen under "Devices > Your iPod" (on the left hand side of the screen) that shows your iPod and some information about it (software version, how much space you've used, etc.)
If you decide to manaully manage your iPod, then there's a tick box towards the bottom of the screen with "Manually Manage my Music". Obviously, tick that if you want to do so.
If you choose to manually manage your music, then you'll need to drag music from wherever (My Computer or from your iTunes library) onto the icon for your iPod. However, if you choose to automatically manage your iPod then sort out your music libray and add the music you want. Then, go to the "File" menu and hit "Sync iPod". The computer also does this automatically whenever you plug the iPod in.
Hope all that helps!
Jan 15, 2011 | Audio Players & Recorders
I have apple ipod 4GB Model MA426 send the songs computer to ipod
Hi there and welcome at Fixya, the support team (lfete)
I mean your iPod you can just insert it in the computer with the cable and the computer will install the driver :O) then you can see the storage in the Folder "My Computer". Open the drive and simply copy and paste the songs you want to have on it, you find the copy and paste function if you highlight a song and then right click on the mouse. Remember this !! you can copy more songs in once by holding the control (Ctrl) button down when selecting the songs with the mouse OR you can copy several songs after eachother by highlight the first song and then press "Shift" and highlight the last song.
you can also use iTunes to transfer your music :
you can find the manual to your iPod here:
http://html-pdf-converter.com/en/convert?u=the-manuals.com/ipod-4gb-ma426-manual/
AND HERE :
http://free-tutorial-for.me/tutorial-for-ipod-4gb-ma426/
For reading the manual you need a PDF-Reader and you can get one for free here :
http://get.adobe.com/reader/
or
http://www.foxitsoftware.com/pdf/reader/
or
http://www.download.dk/index.asp?Kat=kontor&subkat=tekstbehandling&prog=24958&program=PDF%20Reader
or
http://pdf-xchange-viewer.en.softonic.com/
Hope it helps
IF NOT then try to return here
Have a nice time over there
Please rate my answer :O)
Feb 07, 2010 | Apple iPod nano
Trying to download music into my ipod but for some reason i can't doit
First of all check if your ipod is set to auto sync. To check this you need to:
1. connect ipod 2. click on the ipod icon and see if 'manually mange music and videos' is unchecked. 3. if it is then go to the 'music' tab 4. Manually choose your artists, playlists, genres etc to download/sync music from itunes to ipod.
If by download you mean getting music from itunes store directly from ipod then go to Settings > Store and see if your account information is accurate and that you have rights to purchase music.
After verifying this you can go to music store and download your purchased music.
Nov 29, 2009 | Audio Players & Recorders
Hi. i have an ipod mini which is synced to my windows xp system but i'd like to download the music to my mac laptop - OS10. can someone please let me know how to do this ? thanks
Syncing the music to the mac OS10 is much easy please follow the steps below:
Syncing music and podcasts automatically Connect iPod to your computer and open iTunes.
Select iPod in the Devices section on the left side of the iTunes window
In the main iTunes browser window, select the Music tab.
Select the option to Sync Music.
You have the option to sync all songs and playlists or selected playlists. Your iPod will need to have enough free space to sync the content that you have selected from your library. Tip: You can use the capacity bar at the bottom of the iPod settings window to determine how much free space is available. The size of a playlist can be determined by selecting it and looking at the bottom of the iTunes window.
Podcasts can also be automatically synced to iPod. Select the Podcasts tab and choose to sync all podcasts or selected ones. You can also determine which episodes are synced based on if they are recent, new, or unplayed
Click Apply and iTunes will begin syncing the audio content you've selected to your iPod. The iTunes LCD will display the sync progress and notify you when the iPod sync is complete
  1. To disconnect your iPod, select it under Devices and click the eject icon next to it.
Syncing music manually If you prefer not to automatically sync music content to your iPod, you can set up manual syncing.
Connect your iPod to your computer and open iTunes.
In the main iTunes browser window, select the Summary tab.
Select the option to "Manually manage music and videos" or "Manually manage music." This will deselect the automatic sync settings for the Music, Movies, and TV Shows tabs. Automatic syncing for Podcasts, Photos, Contacts, and Games can be individually disabled by selecting those options in each of those tabs. Note: When manually managing iPod, disk use is enabled and iPod must always be manually ejected in iTunes before disconnecting it from your computer
Click Apply.
To manually add music, audiobooks, movies or TV shows to your iPod, choose one of these categories under Library on the top-left of the iTunes window.
Select and drag items you want (to choose multiple items, Command-click items on a Mac or Control-click items in Windows), then drag them onto your iPod icon under Devices.
To add a playlist, select it from the left side of the iTunes window and drag it onto your iPod in the same way.
RNJ VINOD KUMAR
Sep 18, 2009 | Apple iPod mini 2nd generation MP3 Player
When I plug my iPhone into the USB it doesn't
ANSWER: The headphone jack will not charge your iPod. Only the USB will charge your iPod. However, the headphone jack will play music, but the USB will not play music from your iPod.
REASON: The headphone jack does not provide any power to charge your iPod. It isnly has enough power to recieve a music signal.
REASON WHY YOU CANNOT PLAY IPOD THROUGH THE USB: The USB is only intended to be used with a flash drive or external hard drive with a folder structure containing either .mp3 or .wma files. The way the USB works on the system is that it reads all the files and folders on the entire device and will say "reading" until it reads all the files and folders. This should only take a few seconds but if there is tons of files it may take longer. Main problem: An iPod contains much more than just music files and folders - it contains an entire operating system. Worse, the operating system which the iPod uses is protected, keeping other devices except for iTunes from reading the music files.
TO PLAY MUSIC FROM USB (NOT IPOD): You will need to use a flash drive or external hard drive with your USB. This device can only contain music, and the music must be organized into folders. Your iPod will not work. However, you can use Auxiliary input using a cable which both ends are 1/4" headphone jacks, one end going to the iPod and other plugged into your stereo.
SOLUTION: To charge your iPod, you need to plug it into USB. However, to play music, you need to plug your iPod into the headphone jack.
Good Luck! - Chris Proia
Aug 13, 2009 | Dual Electronics XDM6350 Car CD/ MP3...
Transfering music from other to music
If you still need assistance with that issue i know what you should do.
Connect the ipod to your computer and when it shows up in itunes, close itunes.
Then open your start menu and go to My Computer. Here you will see you ipod. Double click on the ipod to open it.. After it is open you will need to click and drag the itunes music folder from the ipod onto your desktop. this may take a while if you have allot of music on it. after that you will add the folder to itunes by going to the File option in the top tool bar of itunes, and select Add Folder To library
Feb 05, 2009 | Apple iPod MP3 Player
Sharp DK-A10BK Shelf System Logo
98 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
