SOURCE: Handset not registering with base
You could try to clear all the memory from the base unit and start again!!!
Instructions to clear phone (Uniden 8855).
1. Go to your base unit.
2. Put your flip phone in the cradle.
3. Press down and hold down (AT ALL TIMES) the end (find hs) button.
4. Whilst holding down this button, take the power plug out of the wall.
5. Whilst still holding down the end (find hs) button, plug the power back in.
6. When you hear a beep from the base unit system.
7. Let go of the end (find hs) button.
8. Your phone memory should be cleared now and you are ready to repeat the process of registering your base and additional handsets.
SOURCE: handset does not work
Your handset is no longer communicating with your base. Depending on your model, the solutions can be a couple of different options. If I could view pdf files on this computer I would look it up for you. But here is the link to the manual on Unidens website- http://www.uniden.com/pdf/TRU8865-2om.pdf
Nonetheless, give this a try. Power down your base, and pull the battery out of your handset. Plug the battery back in the handset and set the bad handset in the base cradle, and then power up the base. Wait about 30 seconds, then give the phone a try. If it still does not work, then you need to try to "re-register" the bad handset back to the base. Look in the manual under "registration" procedures. Hope my help fixes it for you. Good Luck, CG
SOURCE: Uniden DCT648 register phone problem
On the Base Station select HS Registration then on the Handset hold # for 2 sec
SOURCE: Handset No2 displays out of range message
Please check that you have correctly registered the second handset to the base. It may be necessary to de-register the second handset and then re-register it. "Out of range" just means the second handset is not within range of the base phone it was registered to.
SOURCE: bt graphite handset states out of range but is on base
the manaul states that by resetting the phone should solve this. In my case removing the batteries from the handset for a couple of seconds seemed to work just fine.
Regards
