GPS Logo
W
Wayne Breed Posted on Dec 24, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I just received my Tomtom Go2535TM gps. There is no sound. What is wrong?
Settings, voice, picked voice then push test. Nothing. Tried turning up voice. Nothing. Turn sound off, then back on. Nothing. Reset to factory setting. Nothing. Plug into car to charge battery. Tried again. Nothing. Put in Distanation and drove there to see if it would say directions. nothing.
Stan Ford
Level 3:
Genius:
  • Master 3,131 Answers
  • Posted on Dec 25, 2014
Stan Ford
Master
Level 3:
Genius:
Answers
3131
Questions
Helped
905535
Points
9078
Take it back to the dealer for a replacement its faulty
4 Related Answers
Anonymous
  • Posted on Dec 05, 2008
SOURCE: No Sound on my Tomtom one 3rd edition GPS
I did a hard reset (hit the reset button on the bottom with the power on) and the sound was restored when I powered it up. No settings or favorites were lost.
Tim Digibrain
  • 846 Answers
  • Posted on Apr 24, 2009
Check if your audio jack is loose. This can be soldered, I know a gps repair shop that charge $59 for that.
Anonymous
  • 218 Answers
  • Posted on May 20, 2010
SOURCE: tomtom doesn't have sound.
It could be that the sound is kept at a very low level. Tap on the bottom left hand corner. A volume slider will pop up. If the volume is at a very low level increase it by sliding your finger over the slide towards the right hand side. Hope this will solve your problem.
Anonymous
  • Posted on Sep 06, 2010
SOURCE: tomtom Rider GPS won't turn on
My Tomtom rider 2 will not switch on. Battery has been on charge. Appears dead any solutions please?
Cy
4helpful
My TomTom speaks a foreign language that I do not understand, how can I change it to English (USA.)? Tried to myself with no success. Thanks JF
You will have to check 2 settings. First one. Tap on the screen Tap on change preferences Tap on the arrow 3 times You should be on page Preferences 4 of 6 by now. Tap on change language Tap on English US. Tap on Yes.
Second one Tap on the screen Tap on change preferences Tap on the arrow once (You should be on Preferences 2 of 6 by now. Tap on change voice. Select a voice which has English US after the name. Test and select Go through voice preferences Tap Done.
2answers
I lost the voice on my tomtom one
voices can be downloaded from tomtom.com
My tomtom 720 will not turn on
push the reset button for 15 second then push on/off button for 5 second, it will start now
My tom tom one has no sound
Hi! Check your chosen voices and test it! Choose another voice and test it again, if still not working then is a hardware problem... My email is [email protected]
Audio directions
You must ensure that your volume is not on mute. You need to tap on where the words are, not on the map, until the volume slide bar pops up. You may have to tap in different places until it does. If your volume is set normally, you need to check on which voice you have picked. It's under the options. Pick a different voice and test out the directions.
1helpful
Installing Tomtom voices
You can look in the tomtom voices directory with windows explorer while tomtom is hooked to the pc, be sure the voices files are in the voices directory on tomtom.
2helpful
Tomtom 1 stopped talking
Check in preferences > Change Voice to make sure that a voice is selected. If it is, it probably corrupted. Pick a new voice. If none of the other voices work, plug your TomTom into your computer and boot up TomTom HOME and reinstall the voices. If after that they still don't work, contact TomTom support and ask them for advice. They will probably have you send it in for repair on broken speakers.
Please rate, Thank you!
2answers
Cannot Hear Tomtom Voices
yeah you need to go into the settings and activate the voice audio, sounds like its been switched off!
Voice won't work
Have you dtried reseting the GPS. Turn Off unit, take out SD card, at the back of the unit there is a tiny reset button push this with a end of a paperclip and then turn back on and re input the SD card this should return your voice.
Top Tomtom GPS Experts
k24674
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
