Question about Samsung HLN617W 61" Rear Projection HDTV
HLN617W picture froze, turned B&W and grainy, audio OK
My Samsung HLN617W has had the bulb replaced twice and the color wheel replaced twice in 5 years. Today the picture froze in black and white but I still had audio. If this the main board that's out or the analog board?
Posted by Scott Epstein on
Anonymous
  • 67 Answers
Well sorry but this happens to mine to like every 2 years so you need to get a new bulb
Posted on Jul 06, 2009
Samsung hln617w dlp tv won't turn on. Red temp
Had similar problem. Thought it was the lamp. Examined old lamp but it appeared to be good. Ordered a new one anyway. Changed the lamp but the TV screen would not come on. It would make the usual noise as it was going to come on normally but it would cycle 3 times & then turn off. The LED lights in the front panel would indicate a defective lamp. Then read about the ballast. Changed the ballast & still same problem. Tried starting the TV without the lamp installed & noticed that the color wheel did not spin. Removed old color wheel & discovered it was broken. This appears to be the cause of all of my problems. I wish I new earlier of the test-turn on the TV without the lamp being installed & check to see if the color wheel is spinning. Would have save money on the lamp & ballast.
Apr 08, 2010 | Samsung HLN617W 61" Rear Projection HDTV
Ok the details, HLN617W replaced color wheel and bulb works. Tried the power - unplug reset and worked for about 25 mins then I turned it off after no problem. No here is my original problem, after turning...
I WOULD RECOMEND CHECKING YOUR CAPACTIORS (CAPS)ON YOUR BALLIST BOARD (THE ONE THE LAMP PLUGS INTO) IT'S ABOUT 3" X 8" IN SIZE DO NOT TOUCH THE BOTTOM OF THE BOARD!!!!!! YOU WILL END UP IN THE EMERGENCY ROOM. JUST LOOK TO SEE IF THE CAPS ARE BUBBLED OR BLOWN IN ANY WAY.
Feb 13, 2010 | Samsung HLN617W 61" Rear Projection HDTV
My samsung dlp tv model#hln617w keeps turning off. Only stays on for 2 minutes. I replaced fan #2. Thunking that was the problem.
Why did you replace the fan was it noisey and did that cure the noise. These sets commonly have problems with color wheels-do you get motor noise at startup?
Sep 30, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Samsung DLP model hln617w won't turn on (not bad bulb)
Samsung is notorious for having bad color wheels in their DLPs. Well lets just say they are like toasters, they only last a certain amount of time. If the color wheel isn't spinning or is broken, the set will power down almost immediately after you hit the button, you may not even hear the entire fire up jingle. Check the wheel, if you can see the bulb light up for that split second. Actually, check it whether the bulb lights up or not.
Jun 28, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Samsung hln617w non power up
Most of the time when these sets won't turn off it's caused by the DMD but check the color wheel connectors first, especially the flat ribbon cable. Make sure it's in the connector in the correct direction, only has contacts on one side and make sure the ribbon is not torn.
Mar 03, 2009 | Samsung HLN617W 61" Rear Projection HDTV
3 blinking lights and no picture
The whine or squealing you hear is either the color wheel or fan. To determine which, when the noise is heard from the set, turn it off and listen carefully. If squealing stops immediately then Tthe fault is the color wheel, not the fan. And sounds like that are generally the color wheel. A new color wheel is Samsung p/n# BP96-00250A for this model. Vance Baldwin carries them for $97.20 plus shipping. https://www.vancebaldwin.com Logon as guest, select parts and copy past the above part number in without any dashes. Good luck... Bill
Jun 08, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Our Color TV is now Black & White
It could be the color wheel and in fact probably is. I've seen them shatter which would explain the noise. They are glass and spinn at 9000 rpm. An involved repair though definatley a job for a pro. It could be worse, probably a few hundred will do it. Was the TV begining to be a little loud before the failure? Could be a sign, i've seen many noisy color wheels.
May 23, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Samsung HLN617W 61" Rear Projection HDTV Logo
134 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
