Question about Mitsubishi VS-50605 50" Rear Projection Television
Mitsubishi VS-5051 I just got a hand me down TV. I don't have the manual. How do I hook it up for cable tv? I hooked the cable in the ANT A ,have power and sound.Video is not the clear. I have a large black box that appears. Push any button on the remote it goes away for a minute and reappears. It is not the PIP. Also can not get the cabel channels to program in. Really need help.....
Posted by jewels123 on
Lashawn Robinson
    Genius:
  • 1,153 Answers
It is called Text in your Close Caption. Turn off
Posted on Nov 26, 2007
How to hook up a cable remote to a Samsung cable box?
    • 1 Examine the back of the your cable box and the back of your Samsung HDTV. Note which cable jacks are of an identical size and color. Those are the ones that can be used to connect the two devices. Samsung HDTVs cluster all the jacks in a single panel near the power cord.
    • 2 Look at the square rectangular boxes labeled "HDMI In." These are for high-definition multimedia interface cables--combination A/V cables that provide the highest possible image and sound clarity. Look at the back of your cable box for an identical jack labeled "HDMI Out." If you see one, connect the two jacks using an HDMI cable. If you don't, you need to use another set of cables to hook up your cable box.
    • Sponsored Links
    • 3 Check for a series of three round jacks labeled "Component In" and color coded in red, green and blue. These are component video jacks, which provide a good HD picture, but not as good as HDMI. If your cable box has an identical set of "Out" jacks, use them to connect the two components.
    • 4 Look for a pair of red and white jacks (possibly connected to a yellow one). These are audio RCA jacks. If you're using component video cables to hook up your cable box, you will need to hook these two up as well: Component video cables don't provide sound. Any cable box that uses component video cables should also have "Out" jacks for RCA audio cables.
    • 5 Find the raised circular jack with a pinhole in the center of a milky white plastic interior. This is the coaxial jack. Samsung HDTVs label them "Ant In." Every cable box should have a corresponding jack labeled "Out" or "Ant Out." If none of the other cable jacks on the cable box match, use a length of coaxial cable to connect the TV to the cable box through these two jacks. You can also use this connection to hook the TV directly to the wall cable.
    • 6 Turn on your TV and cable box, and set the TV to the input jack connected to the cable box. You can do this by pushing the Menu button on the remote, scrolling down to the "Input" option and pushing "Enter." That will let you cycle through the various input options, labeled by cable type (HDMI, component video). Press "Enter" again when you reach the right component, then exit the menu. You should now be able to watch TV as normal.
Read more: How to Hook Up a Cable Box to a Samsung HDTV ' eHow.com http://www.ehow.com/how_4867255_hook-cable-box-samsung-hdtv.html#ixzz2DwgQRtRE
Dec 03, 2012 | Televison & Video
We have a new Philips 32" LCD TV, 3500 series/32PFL3505D. We are having problems as we try to connect it to our existing Direct TV receiver. Do we need to call for Direct TV assistance, or can you...
Looks fairly straightforward.
Depending on the output of your DirectTV receiver, you are either going to use an HDMI cable.tomcattech17_0.jpg
A component cable: (Red\Green\Blue for video... White\Red for audio)
Or a composite cable: (Yellow for video.. White\Red for audio)
Hook one side of the cables to the Direct TV receiver and the other into the correct inputs on the back of the TV.
Page 9 and page 25 in the attached manual:
http://download.p4c.philips.com/files/3/32pfl3505d_f7/32pfl3505d_f7_dfu_aen.pdf
Hope this helps!
Jun 16, 2011 | Philips Televison & Video
I just bought a 2002 32 inch tv and when i hooked the cable to it it just looks like a ant farm any suggestions
it sounds like you either need to set the input on tv or the output from your source to be correct
if you give me more info about what you are hooking up and to what input with what types of wires i might be able to help more
let me know
good luck!!
Mar 29, 2011 | Samsung LN32A330 32 in. LCD TV
Mitsubishi ws-65313 No Picture
YOU HAVE AT LEAST A DOZEN VIDEO INPUTS ,THE BEST IS THE MONOLINK.WHATEVER WAY YOU HAVE IT HOOKED UP .YOU HAVE TO GO TO THE INPUT MANUAL AND PICK OUT THE ONE YOUR ON .IF YOU DONT WANT TO SPENT 30 BUCKS ON A THE DVI-HMDI MONOLINK CABLE.OR 10.00 ON THE R/G/B TRI CABLE ,FIND ANY COLOR CRAPPY LITTLE SKINNY **** SPEAKER JACK CXABLE AND STICKIT IN THE YELLOW INPUT 1,2 0R 3 THEN GO ON THE INPUT SCREEN AND SCROLL DOWN TO WHATEVER INPUT YOU PUT IT ON.AND OF COURSE HOOK IT TO THE VIDEO OUTPUT ON YOUR BOX SIT BACK AND ENJOY THE 480 P RESOLUTION YOU WIL GET WITH A 50 CENT WIRE.
Jan 17, 2009 | Mitsubishi WS-65513 65" Rear Projection...
60" can not switch from ant a to ant b
Where can I find a bulb for this tv for a good price
Aug 12, 2008 | Philips Magnavox 9P6034C 60" Rear...
Ant/cable
your box might be blown out
also call the cable company to see if the outage didnt affect them
they might be out too
on the TV you might to look for setup or init setup
a model number of the tv set wouldnt hurt too
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Jan 06, 2008 | Curtis-Mathis CM19011 TV
I can't hook it back up
Is your DVD player a DVD/VCR combo? If so, hook the "tv out" (sometimes called "ant out" ) to the "ant in" on the DVD/VCR, then hook the "ant out" of the DVD/VCR to the "ant in" on the tv. Then make sure the DVD/VCR and TV are on the appropriate channel (3 or 4).
If it's NOT a combo, or these instructions don't work for you, i will need pictures of the inputs/outputs of the devices.
Nov 08, 2007 | DISH Network DVR-625 DTV Receiver /...
Mitsubishi VS-50605 50" Rear Projection Television Logo
139 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
