Most scahher have an option to determine where the output should go. I created a foled on my Desktop called "Scanner" and send everything from the scanner to, there.
Testimonial: "scanner is being used with ipad 2. Worked in past. Recently tried using it after approx 7 mos and several ios system upgrades."
SOURCE: Tvichw32 Driver Open Error
Hello Aunt Pat
(01) Is this scanner "new" to the computer it is installed on now (where you're experiencing these issues)?
(02) Did this problem show up w/out apparent cause or relation to any recent changes on your system (e.g. New hardware or software installed, updated, upgraded or removed; system crash; computer repair; etc.)?
(03) Did the problem appear soon after a change to your system? (see above examples)
There are many references to this issue on the Internet. I've listed a few here. You can find many more, if you like, by performing search engine queries.
THIS links to a Roxio forum thread regarding this issue. (Even if you aren't using Roxio software, the information here could be relevant to your issue.)
THIS link will explain a bit about what TVICHW32 driver is.
I'd reinstall the ASPI drivers. A driver file may have become corrupted. (Assuming you'd been using this scanner successfully on this system until recently.)
You can find links for Adaptec's ASPI drivers on their web site HERE. They also have an ASPI version checker you can run to find out what verison is installed on your computer.
** Please, post back here w/ answers to
** these questions and the results of what
** you've tried. We may need to go back
** and forth a few times. We WILL continue
** to work w/ you until your problem is re-
** solved.
** Just be sure to not rate the experts' "sol-
** utions" until that time. Once you do,
** the problem will be closed and we'll no
** longer be able to assist you.
** Thank you @:)
SOURCE: canoscan 9950F won't scan, says scanner locked, but it isn't
I was surprised by the same problem this morning. First time I've had a problem with in years. Checked the lock... it was already unlocked. I solved the problem by unhooking the USB cable from the hub, restarting my Mac (seems to be the key), replugging the cable and restarting the scanner. Worked like a charm. Hope it works for you!
SOURCE: scanner is not detecting images / photos to scan
The image sensor may have gone bad. Try reinstalling the driver, if it does not work... It is time to get a new one (it is more expensive fixing a scanner than buying it brand new). Sorry. Good luck.
SOURCE: need drivers for iconvert photo scanner
says it does, link below.
http://www.ambir.com/ambir/ambir-support
SOURCE: Looking for software to run my Brookstone iConvert
I tried very unsuccessfully to use the software provided with my iconvert. My system even crashed a few times. The provided software, Photo Impression 6, may be good for other things but I was about to send the iconvert back when I decided to try the photo management software I use, Thumbsplus and voila, it works like a charm. You may not be able to do all the retouching and other stuff that the Photo Impression does but I just wanted to get them into my system, then I can do all that work with other software or even with the Photo Impression software.
If you want to get the slides converted and the provided software doesn't seem to work, just try some other photo software like thumbsplus. I have now converted several hundred slides with no problems.
