I had it connected and pressed fn and monitor keys on keyboard
SOURCE: keyboard Fn key
Try hooking up and external key board see if that works ok, and if it does you may want to try to find a new or used key board for your laptop. The key board may be shot, It should be fairly easy to change to a new board, Hopefully That will help you diag. the problem..
SOURCE: Fn key on keyboard seemed stuck
hit shift and "Num Lk" at the same time. Num Lk is abov the F11 button on some Dell keyboards.
Tony Nguyen From Pasadena, CA
www.connectionzpcrepair.com
SOURCE: Fn combination keys for external monitor
Key Combination Functionality
Fn+F3 Reduce speaker volume
Fn+F4 Increase speaker volume
Fn+F5 Switches display: LCD, CRT, and LCD/CRT simultaneous
Fn+F6 Increase LCD brightness
Fn+F7 Decrease LCD brightness
Fn+F10 Toggles battery warning off and on
Fn+F11 Switches the LCD panel off and on
Fn+F12 Places the computer into Hibernate mode
SOURCE: How to control Asus A6R Fn keyboard? when I type
It looks as though you have Numbers Lock turned on. On my Asus x58C this is tuned on and off using the blue Fn and NumLk keys. When its turned on there is a padlock symbol located above the keyboard which is lit. If it is, then hold down Fn then press NumLk and it should turn off. Hope this helps you
SOURCE: FN key on Dell keyboard (model SK-8115)
fn keys are only on laptops
Testimonial: "Thank you!"
