Read manual, hit the off setting when it stated that prevent paper abrasion was on
SOURCE: Printing labels setup on the PXMA MX860
You don't need to do anything to set the printer up except to tell it you have heavier stock than normal.
Your answer lies in the program you are using to print labels. Please tell me which program you are using and what other office type programs you have on the computer and I will try to give you a viable solution.
Chris
SOURCE: Rear Paper Jam - No paper present.
Look for a small piece of paper that may be stuck in the switch indicating a paper jam.
SOURCE: My Canon PIXMA Pro9000 InkJet Photo Printer paper jam error
Had the same problem with mine. Shook it upside down and cleaned it with air cans after reading this solution for other canon printers:
http://www.fixya.com/support/t119769-false_paper_jam_warning_canon_pixma
To my surprise, it worked perfectly... and was great stress relief.
SOURCE: The printer says error code 6c10, then to turn on
It's probably a waste absorber issue.
A fix from FixYa Support:
1. Start with printer off
2. Press and hold resume Button (triangle in the circle) and click "Power" button. Green led should be on
3. While holding the Power button, release the Resume Button.
4. Without releasing the Power Button, click "Resume" button for two times and release Both Buttons.
5. Click "Resume" for four times then soon click "Power" button, to confirm the selected action (reset counter absorber).
6. Turn off the printer and turn on again
http://www.fixya.com/support/t5998845-error_code_6c10_mean
Hope this helps.
SOURCE: Canon MX860 Rear Paper Jam
I have a small piece of paper jammed in my Canon MX-860 that Cannot be seen from anywhere. Can you help me find so I can clear it
