Clean everything really good. next time it leaks you should have a better idea of where its coming from. Like rolling a fat girl in flower to find the wet spot.
Check the front engine seal
Is this behind the harmonic balancer?
Is this behind the harmonic balancer? It appears to be dry.
YES CLEAN ENGINE AND RECHECK LOOKING AT POWER STERRING LINES AND TRANS LINES
SOURCE: 2004 aveo timing belt broke, all valves bent
just go to any junk yard and find a used deawoo lanos and pull the head if timing belt was not broke, if it looks good, its a exact fit 100%, no special tools needed, just normal wrench set and torqe wrench. after head is installed, get a gates timing belt only.
SOURCE: oil leaking from back of motor . changed oil
The oil pressure switch is located on top at the
transmission end of the engine.
If the switch is leaking, it could appear to be coming
from the places you mentioned. Hope this helps.
Good luck
SOURCE: Hi, I have a 2006 chevy aveo and I was recently
Its easy. I did mine about a month ago. You need to take off all the bolts on the top part of the motor. there are some tubes on the left side of the motor by pushing them out of the way... you take the old one off and replace it with the new one making sure its aligned and the you put it back on.. the bolts need to be hand tightened kinda as tight as you would do your tires.
SOURCE: What is causes my chevy aveo to leak oil?
is the valve cover leaking? Is the cover bent? Did you use a new gasket? Where specificaly is it leaking from?
