CAN'T SEE HOW IT COMES OUT OF THE CABINET
Remove the retaining screws from the top of the amp and the screws holding the back lip of the amp (faceing down) on the rear of the cabinet. At that point, it should come out the rear of the amp. It will be snug. You may also have to remove the handle from the top of the amp and the metal corners for clearance.
SOURCE: Peavey KB 100 Keyboard Amplifier How to remove chassis?
I figured this out myself. I was just babying it too much. Some tolex had bunched up between the metal chassis and the cabinet making it feel like it was caught on something. I used a flat edge screwdriver to flatten out the tolex, and then I was able to pull the chassis out the back of the cabinet.
SOURCE: Amplifier not working
It is more likely that your input jack component is broken or damage you would have to take it apart because your circuit board may need a look at to check for damage and you will need a new input jack
SOURCE: where 's the fuse for
The fuse is INSIDE the unit and if it blows, then there are other damaged components that require going to a repair shop to repair before replacing the fuse.
