Televison & Video Logo
P
PATRICK A CARLEO JR Posted on Dec 23, 2014
Premium channels don't work with hr44 genie and hdmi
2answers
Need helping hooking up to my existing directv box
About 409,000 results (0.52 seconds) Search Results
    DIRECTV Genie® WiFi Setup & Connection ' DIRECTV ...
    https://support.directv.com/.../directv-genie%26reg%3B-wifi-set...
    DirecTVWatch this video to learn how to connect your Genie® HD DVR model HR44 to the Internet. Follow the simple ... No, my router does NOT have WPS or I want to configuremy router manually. Image .... Order DIRECTV Existing... Still need help?
    Do I need additional equipment to connect more than one TV
    https://support.directv.com/app/answers/detail/a_id/3945
    DirecTVYou need one Genie Mini or Wireless Genie Mini for each additional TV. ... So in a Genie Whole-Home HD DVR setup, one of your TVs is directly ... which allowsDIRECTV Ready TVs to be connected to the Genie HD DVR as additional TVs in your setup without a Genie Mini. ... Order DIRECTV Existing. ... Still need help?
    How to Connect DIRECTV Receiver to TV ' DIRECTV Support
    https://support.directv.com/.../how-to-connect-directv-receiver-t...
    DirecTVHow do I connect my DIRECTV receiver or Genie Mini to my TV? ... This will help you determine what cable to use. .... To download and print them, you'll need.
    My equipment was shipped to me. How do I install it ...
    https://support.directv.com/app/answers/detail/a_id/4267
    DirecTV
Trying to reconnect my WD drive with exiting data to a new directv genie
Your answer may be here.
http://www.dbstalk.com/topic/206052-upgrade-internal-hard-drive-on-hr44-500/
NEED TO ADD CODE TO URC REMOTE
Try these instructions and see if they work for your genie remote.
First, have your Genie Mini receiver connected and powered on. Next, grab your RC71 remote and simultaneously hold the "MUTE" + "ENTER" buttons until you see a box appear on your TV screen that says "Applying IR/RF Setup. Please Wait" (this appears after about 5 seconds of holding those buttons). Once complete another dialog box will appear and read, "Your remote is now setup for RF." Click "SELECT" to exit that screen. Next, click the "MENU" button, scroll down to "Settings & Help", then click on "Settings", scroll down to and click on "Remote Control", then click "Program Remote". Next you will have two options, either "Program TV" or "Program Audio Device". Click "Program TV", this takes you to a screen where you need to select what BRAND your TV is. After you have selected your TV brand you will have to select the TV Model ( I recommend looking at the sticker on the back of your TV for the accurate Model number or using your current TV remote to find the model number from the menu screen on your TV for fastest and best results). Once the correct model number is selected, AIM your RC71 remote at the TV and it will AUTOMATICALLY program!
1helpful
2answers
Cant get new HDMI board for Onkyo TX-SR604
It's usually the hdmi switching IC that goes bad on these. Not something you can really replace without the right equipment and knowledge.
8helpful
4answers
Lg 42ls575t won't go to "input" screen or "home" screen so cannot select HDMI channel. "Loading" message appears for 30s or so then disappears
solved.
1- turn off you router
2-go to settings
3-ok on the ? (support)
4-inatialisation of premium.
Problem solved
I bought a brand new xbox 369 last night. i also bought a brand new 32" flatscreen emerson le320em3. is this tv not compatible with an xbox 360? i was able to get the tv hooked up to cable and the...
Your problem is in the TV. I'm not familiar with your TV, but you should look for an option to turn it to normal or to try and scan for channels with xbox plugged in and running. I'm pretty sure that if you get HDMI cable, your problem should be solved.
Picture has red tint when macbook air is connected through HDMI
I have exactly the same problem with my mac mini when I connect it to my Sony Bravia with an HDMI cable which works fine with my Apple TV. Sorry I don't have an answer yet!
Can I hook up my vh242h monitor to satelite box and if so what connections do I need
First, look on the back of your satellite box and look for one of the first 3 connectors on this site:
http://ixbtlabs.com/articles3/video/guide-p5.html
They depict D-Sub, DVI-D, and HDMI ports which are all compatible with your monitor. I would suggest HDMI, but any would work fine. You can get these cables at any electronics store (BestBuy, Walmart, etc.).
If you don't have any of these connectors on your satellite box, you will need to get a converters such as this:
http://www.amazon.com/Wired-Up-Premium-7-62M-Component-Cable/dp/B000QEDE76
If these links don't help, reply with what model satellite box you have and I can provide more specific instructions.
Good Luck!
John Vickers
I PURCHASED A MAGNAVOX Z V 427MG9 A VHS DVD RECORDER.I HAVE A NEW VIZIO VW26L HDTV. HOW DO I CONNECT THEM? I HAVE ALREADY CONNECTED A HDMI CABLE TO IT BUT DON'T KNOW TO SET IT UP. DO I NEED ANY OTHER...
HDMI cables are actually wonderfully simple to connect. Once you have connected one end to the TV and one end to the DVD player, you will simply need to change your input channel using your TV's remote. Find a Input or Video source button and press it until the screen says HDMI. Now your TV may have several HDMI ports so you may have to try a couple HDMI channels before you find the right one.
Hope that helps!
2answers
Hi I have a 32 inch hd vizio tv and a ps3 system and I bought s Belkin hdmi audio and video cable and I'm trying to figure out how connect the cable to the tv and ps3 to get hd channels and hd games and...
Cable: First you need to be using an HD Cable box to get the HD channels that your provider offers. if you don't, you can't get HD channels. Keep in mind that not all of the channels that your provider offers are in HD. Out of the 300+ channels that my provider Cox Communications in Las Vegas offers, they offer 91 of them in HD. If you have an HD box, you need to go into the settings menu and make sure that your video output is set to constant as you do not want it bouncing between different resolutions when you change channels. In your case you will have two options, 720p and 1080i (1080p does not exist for cable due to the amount of bandwidth required). Choose 720p because your set is under 40" and you won't see a a difference between 720p and 1080i except for that because it's progressive, HD may actually look better. (NOTE: although your analog channels will display at 720p, they are not in HD. They are simply up converted SD so don't expect that they will look like HD channels.) Also be sure to set your audio settings on your box to "HDMI out."
In general, HDMI devices should automatically detect HDMI input but since I don't know what kind of box you are using, it is possible that HDMI-out is disabled in the settings. My box (Scientific Atlanta) doesn't have that option, but I don't know about others. As far as the set is concerned, plug the HDMI cable into the input you want to use (if it's a new Vizio, I'm assuming there are three inputs as that's what my 32" Vizio in the kids' room has) and the set will auto-detect the HDMI input and automatically set the resolution accordingly.
SIDE NOTE: The only other way you're going to get HD channels from cable without a box is if you're using your COAX cable directly in to the TV and that is only if your cable provider has them floating on the line and you're only going to get the 5 major networks and Univision in HD.
PS3: This is even easier. WIth your PS3 powered off and your TV powered on, connect one end of your HDMI cable to the HDMI out on the PS3 and the other end to the appropriate HDMI input on your TV (of your choosing). Power on your PS3. Your TV will automatically detect the HDMI input from the PS3 and put that HDMI input on the screen. You will get an on-screen message from the PS3 detecting HDMI and it will ask you if you want o use HDMI or words to that effect (I can't remember the exact message... it's been a while). Choose "yes" and it will adjust the picture accordingly and should automatically choose the highest video resolution your television can display. To verify your settings, first hit the "guide" button on your Vizio remote control and in the upper right corner it will tell you at exactly what resolution it is displaying at. If it's not where you want it to be, on your PS3, go the Settings Menu and scroll down to "Display Settings" and the first item on the list is "Video Output Settings." Follow the step by step on screen menu prompts to determine your display settings, and choose "automatic" when prompted. If everything is copasedic, the highest resolution your television can display at will be listed at the top (and will be the current setting) and all of the other resolutions will be listed below it. If something is wrong between the "handshake" between the HDMI from the PS3 to the TV and it doesn't display in HD, go back into Video Output Settings" and when prompted, choose manual in stead and set the resolution on the PS3 the highest your TV can display. NOTE: Most 32" TV's have a maximum resolution of 720p fir the reasons I stated earlier. Check your manual for the specifics on yours. Furthermore, all PS3 games are in 720p so even if you have a 1080p TV, don't expect higher resolutions than that. AS far as Netflix is concerned, not all of their programming is in HD. The scale for Netflix is SD/Low/Medium/High/X-High. HD/Low/Medium/High/X-High, your quality depends on the program and strength of your Internet connection.
Closing: I'm a little confused by your issue as HDMI is automatic and you should automatically be getting HD so the only other thing I can think of is that your display needs calibrating and you just think you aren't getting HD. In order to get the most out of your new TV and your PS3, I would highly recommend that you calibrate your set with a Blu-Ray calibration disc that comes with color filters. It will take you about an hour or so to get the hang of and use correctly but the results will be very noticeable. The presets that come out of the box and the settings that they use on the floor in the store are awful and you don't realize how much you've been missing in picture quality until you calibrate. Do not rent this disc from Netflix as it does not come eith the color filters. You can buy a calibration disc at Amazon. I got the DVE one, from what I understand, the Spears and Munsel one is very good as well.
http://www.amazon.com/s/ref=nb_sb_ss_i_0_24?url=search-alias%3Daps&field-keywords=blu-ray+calibration+disc&sprefix=blu-ray+calibration+disc
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
