Ovens Logo
n
nigel lewis Posted on Dec 22, 2014
Just purchased a new grill and oven element for a hotpoint ew74 oven but forgot to draw a diagram which wire goes where on the element please help
Everything
Have a hotpoint eg900 . The oven element is new and so is the grill element but still no heat from either . Would the thermostat be at fault ????
I don't think the thermostat would be at fault because neither of your elements are heating up. On the back of your range there are sometimes plastic sleeves that have a wiring diagram folder up in them. If you can scan that in and post it, I may be able to help.
Nov 23, 2012 • Ovens
1helpful
2answers
Grill not working after replacement element - any ideas?
I would say you are right on your wondering. look at your manuel and it will show you a diagram
3helpful
The grill on my Hotpoint EW 41 Electric freestanding cooker has stopped working after my wife put aluminum foil into the grill pan which then touched the grill element causing it to 'blow' and so...
The grill element should not 'blow' by just touching it - it should be earthed. The elements do gradually disintegrate over time & the inside wire element either fractures or touches the element casing causing the mains to trip. Sometimes this makes it trip just once & then stops working. Replace the element - not usually any fuse in circuit with this. Often held in by 2 screws adjacent to the element at back of oven and conections via Fast-ons- Rick
3helpful
Hotpoint sy36x grill element works fine but when switched on to oven it doesnt heat up, fan working.
it seems to me that it is a fan oven and the top element won't heat up you need a new fan oven element. it is a round element that sits behind the back grill surrounding the fan...
regards
richard saupe
appliance repairman
1helpful
How to replace element on my Hotpoint main oven BD31
If it is the main oven element, then undo the screws that secure the cover at the rear of the oven, remove cover, and you will see the round element there.
Undo screw securing element, and pull forward in to oven compartment.
Detach the wires, and fit new element.
Hope this helps you.
Please leave feedback.
Thankyou.
3helpful
2answers
We have a hotpoint cooker UY46, our electric tripped the cooker off and , now the nob and grill works but the bottem/main oven is turning on and the fan is circulating but not getting hot ? please help ;(
You need to replace the element. Very easy job remove the back plate from inside the oven (4 screws) and you will see a circular element held in place by one screw in the centre of the fixing plate. Remove the fixing screw then remove two wires and refit new element job done.
Regards Neville
3helpful
My hotpoint bs32 oven went bang when I turned it on aftewr a while. I replaced the fuse and the grill and all the functions light up and work except the oven. The fan is working but the oven is not warming...
The fan oven element has failed, you need to replace it with a new element.
You need to remove the inner rear cover of the oven.
There you will see the element..
Unscrew and disconnect the leads and refit new element, be care ful not to lose the wires behind the element aperature.
Plz rate my solution.
Thanks.
Jan 05, 2009 • Ovens
4helpful
Replacing electrolux eob944 fan oven grill element
...If you can help me to remove the grill element from my EOB944, I will be able to tell you the wirings.
Top Hotpoint Ovens Experts
Mike Cairns
Mike Cairns
paul fairbanks
goneforever.
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
