Question about Shopnbc Zeki 7" Multi-TouchTablet
Having problem with the sound. Only can hear with headset... Is that how this table is set up?
    Champion:
  • 203 Answers
It is very possible that the earphone jack is defective and causing the problem. I had a tablet that would not make any sounds through the speakers after I plugged into the earphone jack and then removed the plug. I could hear only through the earphones after that. The problem was caused by a fault in the earphone jack. I had to send the tablet back to the manufacturer where they replaced the faulty jack. But before you send the tablet back to the manufacturer make sure that the tablet isn't muted by going to "settings" then go to "sound" and see if it is turned down or muted.
Posted on Dec 23, 2014
  • Jena Ulmer
    Jena Ulmer Nov 30, 2019
    They said can hear with headset not without.... sounds like a speaker issue
6ya staff
SOURCE:
Which bluetooth headphones work with digiland 8 tablet?
hi try it go to settings
devices
search for your Bluetooth headset
click on your bluetooth headset device
it will connect your blotch headset to your tablet straight away
Mar 11, 2018 | Tablets & eReaders
My sound isnt working. What do i do?
Hi click on tools or settings icon should open a page with all the settings look for SOUND Click it on & check the settings volume adjustments. .good luck
Jul 18, 2016 | Tablets & eReaders
How to pair lg Bluetooth headset with ipadair?
on your iPad go to setting-> then down to bluetooth. on your headed set Press and hold the multi-function button for 10 seconds until the indicator light turns blue. It is now in pairing mode. it should show up on your iPad, click on your headset and it should pair.
Nov 26, 2015 | Apple iPad Air
When I plug the headphones into my Samsung Galaxy 10.1 tablet, the sound comes from both the headphones and the speakers on the tablet, shouldn't the speakers be turned off by the headphones?
This can be a hardware (bad headphone jack) or a software (rom update) issue. If the tablet is in warranty, try taking it to your dealer and see if they have a fix.
Otherwise, some people have had success doing one of the following:
1. Plug headphones in after starting music. Watch for headphone icon to appear on screen, meaning tablet has recognized that headphones are attached. Make sure plug has been put into socket all the way.
2. Install app SoundAbout on your tablet and see if you can route sound to headphones only.
3. Check Settings/About Device to see if there is a software update for your tablet. Install the update and see if that fixes the problem
Jan 12, 2015 | Samsung Galaxy Tab 101 Tablet...
Low sound can hardly hear it even tho the sound is turned high
Sometimes the app you're using has it's own sound control that overrides the device sound setting. Look in the app for sound settings, eg audiobooks apps often have a separate setting for volume and this is the one that you need to adjust.
Jan 01, 2015 | Tablets & eReaders
How do I get table to unlock hannspree table will not switch on after having battery topped up
This could be a couple of things:
- Try unplugging it from power source,
- try to reboot by holding powerbutton for more then 20 seconds
Please let me know if this worked out!
Oct 16, 2014 | Hannspree 10.1" Android Tablet Grey Tablet...
Ematic table em63bl
If you are trying to factory reset your tablet, go to settings then go to backup & reset. There should be an option to factory reset your tablet which will delete anything you installed or downloaded.
Apr 07, 2014 | Ematic e8 series
Sounds and discplay
There is some corruption, I think a factory reset should do the trick.
Apr 26, 2017 | Nextbook Premium 8 Se Android
How can i turn volume on my dopo m975
(Tap the settings icon in app launcher to get to the settings menu)
Go to settings then device sound
set volume levels and turn sound ON/OFF
Feb 02, 2013 | Tablets & eReaders
How To fix sound for Toshiba Satellite.
Sound issue can be related to driver, sound settings or hardware itself. If you tell me more about the issue an I will give you step by step solution.
Check if device manager shows the Sound device? When you play a media file does it indicates any error message? Have you unmuted all the channels?
I will look forward your follow post
Jan 10, 2008 | Toshiba Satellite R10-S802TD Tablet PC
Shopnbc Zeki 7" Multi-TouchTablet Logo
192 people viewed this question
Top Shopnbc Tablets & eReaders Experts
The Scrivener
 Mike M
Mike M
Giulio Moro
Are you a Shopnbc Tablet and eReader Expert? Answer questions, earn points and help others
