Question edited for clarity. 'field cycle' to fill cycle.
Do you hear water running? Water inlet valve failed.
or
Taking too long to fill. Check the strainers in the rear where the hose connects and check water flow from the hose.
Also try a power disconnect overnight to do a power reset of the control board.
============================================= If the cold water supply is slow or not entering the tub at all, the washer will stop ahead of the rinse cycle while waiting for the tub to fill. This can be caused by a clogged water inlet valve, the main water supply valve being partially closed, or low water supply pressure from the home.
The filler hose has a wire mesh filter in it to keep the inlet water from passing particles that would keep the solenoid valve from closing completely. Shut off the water and take the hose off from both the faucet and the washer. clean the screen and check the one in the washer too.
NO
persistent running is problem valve washers either in the water level control or the flush washer under the press buttons
low pressure will take a longer time to fill but when the level is attained the water will stop flowing in
if it fails to stop running only at the rinse part of the cycle it is probably in the timer as the solenoid valve has to cut the water off when the washer fills for the wash cycle too. fills for wash cycle and cuts off water, washes and drains, refills for rinse cycle and water just keeps running? does this every time you run it? that's in the timer. bad solenoid (water inlet valve) would keep running even on wash fill up. hope this helps.
check to make sure the control knobs are turned to exactly small -med -or large - if it's in the middle of say med and large loads the water will over flow - this happened to us three times (cause of daughter!)
If the cycle does not stop draining that is usually because of a faulty
membrane switch that controls the water level in your appliance.
The faulty sensor cause the machine to think that there is still water inside, even when water has drained completely.
filling and never stops and never agitates? then check level switch and hose, any hole in the clear hose to the level sw can cause this. if airtight then replace level sw.
i would recommend checking the water level switch or lid switch and also the cable leading to it. that is what sends a signal to the machine control to stop filling with water.
