Compaq Presario R3000 Notebook Logo
Question about Compaq Presario R3000 Notebook
I had to reinstall windows xp on my compaq presario r3000 after an unsucessful instal of windows 7 (not enough room ) and i need drivers but am unable to install them all (only2 so far) it says i dont
Compressing some of the files
Posted by linda VanVranken on
5 Related Answers
Anonymous
  • 239 Answers
SOURCE: Windows XP Driver for Compaq Presario V702TU
Ok I take it you still have an internet connection, If you do open your device manager and you should see some yellow question marks by some devices, Now select the ones with the marks by them and make sure you are on line and right click and select update drivers, that should get you up and running if it does not write back here and tell me what is missing and I will find them and get them to you, But I am pretty confident that doing the update it should reload and find what you need... Thanks
Posted on Jan 17, 2008
Anonymous
  • 11 Answers
SOURCE: need wifi driver for presario c754tu with xp pro support
try visiting your laptops vendor website and download your driver for windows xp, just have patience or email me @ [email protected] and i will gladly help you download your driver
Posted on May 10, 2008
sree184
sreeradh p.r
  • 87 Answers
SOURCE: Sound Drivers for Windows Xp
Hi
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-43414-1&lc=en&cc=us&dlc=en&product=3327556&os=228&lang=en
please click the above link and down load driver
Posted on Jul 15, 2008
Anonymous
SOURCE: Compaq Presario C795TU drivers
i dont have drivers for c795TU
Posted on Sep 20, 2008
Anonymous
  • 89 Answers
SOURCE: Audio not working
A few things have had probs with SP3, maybe take it off and reinstall the driver:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=99905&lang=en&cc=us&taskId=135&prodTypeId=321957&prodSeriesId=96403
Posted on Oct 28, 2008
Compaq Presario 2050NX onboard pnp nic (LAN) device not found - reinstalled onboard LAN device driver, still can't see it
For Windows XP CLICK HERE
In Windows 7 the driver installs automatically
I would suggest uninstalling all drivers for the network adapter then reboot and allow the system to find the NIC again. If this is Windows XP uninstall all drivers for the NIC, reboot, and install the above driver.
If it is Windows 7 uninstall the drive, reboot and allow device manager to locate the driver itself.
1helpful
2answers
Install windows xp in compaq presario cq45
There is no drivers for Windows XP for this notebook, only Vista and Windows 7. My advice is to install Windows 7 - it works just fine.
COMPAQ presario AUDIO none
Check Device Manager to see if the Audio device is working and enabled, if not install the latest audio driver.
You need to download the drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the XP or Vista Windows version of the drivers you require and install them. Use this link to download the drivers: -
www.compaq.com/country/cpq_support.html
Sound driver
http://h18000.www1.hp.com/cpq-country/cpq_support.html
3helpful
Compaq presario cq45 112AU unable to install winxp
U need to edit the BIOS settings because SATA drivers is not included inside older Window XP CD.
Disable the SATA option under advance options in BIOS. That should work and it will also allow you to install/reinstall Win XP.
Presario r3000 too slow
I have a R3000 and after many years of usage many things happen and add to your hard drive. It can be a number of things from not enough hard drive space for your cache file to bad installed drivers.
I would suggest a full format and install using the backup disk that Compaq sent with the system. You should have the WinXP code on the bottom of the computer. This way you get a 100% clean system. You will have to reinstall any additional software such as MS Office or your virus scanner.
Hope this helps
2helpful
2answers
I want compaq presario v3500amd drivers
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&lang=en&product=442915
this link is for
Compaq Presario R3000 (AMD) Notebook PC
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&product=385190&lang=en
this link is for
Compaq Presario 2100 Notebook PC (AMD)
Compaq presario r3000 windows update failed
you don't have the legitimate serial key fo rth Windows XP.
sorry we don't porived help for cracking the serial number.
you just have to work with sp3. without any updates.
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
Marvin
Marvin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
