Question about Denon Audio Players & Recorders
There is no sound coming out from my Denon 982. Another problem is my remote control is not working and could not find a service center or store where I could buy a replacement.
Press the on/off button while pressing the A & B speakers, tried master volume control and the channel controls.
Posted by Rey Garcia on
Dennis McCollum
  • 137 Answers
Plug in headphone then un plug then see if vol came back(a secret tip)
Posted on Feb 19, 2015
5 Related Answers
Anonymous
SOURCE: Unresponsive remote
Had same problem with this reciever over the weekend. I had to hook up a TV to the COMPOSITE monitor jack and then I could see the menus. I could never get it to show the menu over the component outputs, however a DVD player hooked up played perfectly. Anyone have a solution?
Posted on Feb 18, 2008
robotek
Graeme Ross
  • 1512 Answers
SOURCE: no sound
Hi guys
It sounds like the unit has locked up from a power flip type situation. I suggest powering the unit down completely overnight and then fire it up again in the morning and see how it behaves. Some of your system menu presets may have lost their settings and may need to be setup again also. Get back to me here if you have the same condition after doing a full reset in this manner.
regards
Graeme
Posted on Mar 08, 2008
John Weinreich
  • 336 Answers
SOURCE: Marantz SR5200 receiver works only with remote not manually
Check for a stuck/jammed switch, press each switch if one doesn't make a normal click sound or it doesn't move at all that's your problem.
If that's not it check the owners manual for how to reset the receiver (not all manuals will tell you how to reset it) Another way to reset it is to short the memory cap, but that is better left to a tech.
Posted on Feb 13, 2009
Anonymous
SOURCE: remote control problem
try pressing the TUNER button on the top of remote before pressing these buttons
Posted on Sep 04, 2010
Anonymous
SOURCE: Yamaha RX-V1000 volume control erratic, remote
Hi.
The volume knob issue alone sounds like it's hardware-related and therefore not easily fixed. Also, since the remote appears to be working (the LED's are lighting up), but the unit is not controlled anymore, the IR sensor is probably faulty as well. I would seriously consider sending this AV receiver in for repair. If it's still within warranty, you shouldn't need to pay anything for the repair.
Manual for your receiver: http://www2.yamaha.co.jp/manual/pdf/av/english/re/RX-V1000.pdf
It's not much but I hope this helps.
D
Posted on Aug 21, 2011
Tip
How to set your clock radio
Press and hold down the "clock" button. You should see your time start flashing. Normally you set the time with the volume or channel control, or both, Volume for "Hour" and channel control for "Minutes". Check which control lets the selector jump from "hour" to "minute and set the minutes. To exit settings menu, depress "clock" button again
on Dec 02, 2009 | Car Audio & Video
Panasonic CT 27 SL - 13 GL how to connect external speakers
This TV is set up to connect to an external amplifier which that controls the speakers. It has an analog audio output which means you need an RCA audio cable (2 RCA plugs (red and white) on each end. You can't directly connect a set of speakers. The audio output jacks at between the antenna in and the video inputs. Then you need to enter the menu and enter the Audio submenu. Go to the Speakers item. Turn the TV speakers to off and fixed audio out.(The amplifier will adjust the volume.) Use the Up/Down arrows to navigate through the menu options, press enter to enter a sub-menu and the volume up button to change a setting.
There is also a headphone jack which may be compatible with computer speakers. That has a 3.5 mm jack. To use headphones, set the Speakers Audio item to TV speakers Off and variable audio out. (The TV controls will adjust the volume.)
To use a Universal remote to set the audio or modify the channel list, you need one that matches the Menu function of the original remote. You may need to try multiple codes for Panasonic TVs to get the button to work. Some low-end universal remotes may not have the menu button; get a different remote or use the menu button on the front panel of the TV.
To set the channel list, press Menu and select Setup. Go to the Prog Chan option. Then set your Mode in the first option (Cable or Air). Then choose Auto Program to scan all channels or Manual Program to edit the channel list.
The manual for the TV is available at retrevo: http://www.retrevo.com/support/Panasonic-CT-27SL13-TVs-manual/id/275ag210/t/2/ . You will need to enter a code to access the manual. See page 5 of the manual for the input connections (page 7 of the PDF).
Sep 13, 2012 | Panasonic Televison & Video
How do i get the parental lock off my set
Hello
To reset the parentian lock password in Vizio TVs do the following
* Get into it MENU and come towards Parential Controls window.
* When the MENU button is pressed, the On Screen Display (OSD) appears on the Image Settings page.
* Press the [Channel Down] button to change to the Parental Controls page.
* Press the OK button and the first of the 4 Password boxes will be highlighted.
* Press the [CHANNEL UP-> CHANNEL DOWN-> VOLUME UP-> VOLUME DOWN] buttons in this exact sequence. Press the OK button
* The password has now been reset to "0000" and the following message will appear.
You can reset it after. The above said buttons will be on the center of the remote control within a circle. OK.
Jul 11, 2011 | Vizio 42 in. LCD TV
Volume control.have craig mp3 player cmp616f. how do i turn down volume ?
press the volume control once - the speaker picture on top should blink, then press the fwd or bkwd buttons on either side. if the speaker does not blink, press the volume control again. do not hold the volume control in.
Feb 16, 2011 | Craig Audio Players & Recorders
YAMAHA AV receiver RX-V861 I have the message 'Vol-fix' appearing on Zone 2 and no sound. This was working fine until then
Setting the RX-V861 remote control to operate Zone 2:
  1. Using a ballpoint pen or similar object and press the [CODE SET] button RX-V861 remote control. The[TRANSMIT INDICATOR]on the remote should flash twice.
  2. Using the [NUMERICAL KEY PAD] on the remote and key in 9992, the [TRANSMIT INDICATOR] should flash.
Assigning the receivers internal amp for Zone 2:
  1. Set the remote control selector to [AMP]. (Located to the right of the volume buttons on the Remote.).
  2. Press the [SET MENU]button on the remote control.
  3. Arrow down to Manual Setup and press the Enter button on the remote control.
  4. Arrow to the [SOUND MENU] option and press the [ENTER] button on the remote control.
  5. Arrow to Speaker Set and press the [ENTER] button on the remote control.
  6. Arrow to the EXTRA SP ASSIGN and select ZONE2
  7. Press the [RETURN] button on the remote control to exit out and return to the Manual Setup.
NOTES: There is an option for setting the Maximum Volume and Initial Volume in the Zone Set menu.
  • Max Volume: This is an optional feature but isrecommended to prevent the accidental change in volume levels thatcould damage the speakers and receiver.
  • Initial Volume: This is also a great feature that would seamlessly start the volume level for the second or third zone at the desired level.
We do not recommend using any Speaker Selector boxes to enable more than the recommended number of speakers per terminal.
Controlling Zone 2 using the RX-V861 remote control:
  1. If the Main Zone on the receiver is on, press the [POWER BUTTON]down and while holding that button down press the [PHONO]/[**] button on the remote. The [TRANSMIT INDICATOR] will light up.
  2. You will not be able to use the following buttons on the remote: (Pressing any other button will cause the remote to exit Zone 2 mode. [POWER], [STANDBY], [VOLUME], [MUTE] and the [INPUT SELECTOR] buttons [DVD], [CD], etc.)
There are the instructions as written straight from yamaha. If you need any further assistance please let me know.
Thank you,
Lee
Dec 13, 2009 | Audio Players & Recorders
The volume of the callers voice is so low that it is almost inaudible
u increase the volume.....for example make a sample call...while calling now press the forward direction button in ur mobile....volume ll increase...
hope this is helpful!!!!!
Sep 29, 2009 | Cell Phones
I have a new TV Model 47PFL3603D/F7 and am hooked up to comcast digital box and cannot figure out how to get my comcast remote to regulate the volume. I have the set on channel 3 and everything works...
Usually on a universal remote (after programmed) the volume is controlled by pressing the cable button then adjusting the volume. When you turn your tv on by pressing tv power---then flipping through the channels by pressing cable--channel up or down. The remote (in my experience usually only controls the volume while in the cable mode)
Jan 10, 2009 | Televison & Video
Half of controls work
Flashman,
It sounds like the remote might be in TV mode and not CBL mode. When you press the List or Guide buttons, the CBL light on the remote should light up. If it doesn't, press the CBL button (located right under the master Power button) once, then try pressing List or Guide again.
Nov 18, 2008 | Arris DCT6200 DTV Receiver
193 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
