Cuisinart DCC-1200 Coffee Maker Logo
Question about Cuisinart DCC-1200 Coffee Maker
It takes over an hour to perk a pot of coffee and it sputters and
Hisses.
Posted by cyberj50 on
Anonymous
  • 85 Answers
Hello cberj50,
I recently had this similar problem. If you still have your machine try the following.
Your described problem may be one of two problems. Let's start with the easier solution first. In the DCC 1200 there is a filter "stick or column" in the left rear. Pull it out and remove the clogged carbon filter(s) that are in there. Shine a light into the receptacle and remove the debris in the bottom. It is likely that this is causing the problem with you machine needing to be started on multiple times. See if this solution works. If it does, you might run 8 cups of water and 4 cups of vinegar through to help decalcify the units plumbing. Do this once or twice and then rinse with at least one pot run-through of clean water. If this works then you are good to go.
Next, if this does not solve your problem we can do the following: unplug the unit and lay it on its back. You will need a #10 torx driver (hardware store if you don't have one) to remove the bottom cover plate. There are 4 torx screws holding it on. When removed, you will find 2 orange hoses. Carefully attempt to remove the left hose without splitting. I used an eyeglass screwdriver to loosen it up. If it splits, just cut off the split and stretch it to reconnect when time comes. As you look into the hose you will find a little black valve inside as well a some gunk. Clean it all out with a fine wire as best you can. Rinse well. Attempt to reconnect the hose back onto the pipe. Slip the pipe clamp back into place. Replace the cover and screws and you should be good to go again. This is not as daunting as it may seem. You can do it. :o) Good luck! If this answer helps, please leave positive feedback for me. Much appreciated. Regards, NormanZ
Posted on Jul 08, 2009
Anonymous
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 9 Answers
I cleaned my Melitta and then took bottom off and removed the two clear silicone tubes and made sure there was no gunk in the metal tube that runs in a u shape against the heating element. Then I looked at the cold water inlet tube that has the check valve right near where it connects to the bottom of fill tank. That looked fine. I looked at the filter basket that has the 'pause and pour' feature of an insert with a spring and a silicone gasket that when the filter basket is in place, the unit lid down, and the carafe on the heating element, the lid of the carafe has a raised bump that applies pressure to this spring loaded stopper. I checked it and the spring seemed to have lost its tension and wasn't pushing against the bump on the lid very well. So I removed the spring and stretched it. It is better to buy a replacement spring as stetching it causes springs to loose their tensile strength, but I had none to switch out, so I stretched it pretty good and put it back in place. Now there was good pressure when the carafe lid pushed against the spring mechanism. I reattached all and with bottom left off, prepared a 4 cup amount of coffee, using 2 1/2 Tbsp. of ground Yuban. I carefully lifted the entire unit on top of three equal sized canisters to give me a view of what is going on underneath when the unit brews a pot of coffee. I was careful to make sure the unit did not wobble, or were any distractions. I plugged it in and turned the cycle on. It ran fine, until towards the end of the cycle. I could see all of the last remnants of water had emptied into the upper part of cold water inlet, below the check valve, and it due to the curve J shape of the cold water tube, the water wasn't traveling into the heating element tube as quickly as it should, so it kept hissing and sputtering and back flowing, but not beyond the check valve as it was the last bit of water. I carefully tilted the unit towards the front in the direction of the heating tube and it did fine then, traveling into the heating tube and traveling up the outlet tube. So, a good thing to look at if you coffee maker sputters, even after you've cleaned it and kept it clean and made sure the check valve doesn't have mineral deposits gunking it up, then check the level of your unit. Make sure it is level or just a bit tilted up in the back. I use folded bits of foil smashed into squares of equal depth and place them under the rear foot pads. You may need to tilt it in a different direction depending on which way the cold water inlet tube travels to the heating element. This worked for me.
I also found out my counter top has a low spot in the center area and high spot towards the front, and where I had it placed, its rear end was low enough to cause the imbalance in rate of flow.
Posted on Feb 14, 2012
How can I fix my 55 cup Farberware coffee urn FSU 255 model and it won't turn on. Any suggestions? It's always worked well before--this is a new issue.
If it will not perk or even get warm, the main heating element (usually in the middle of the pot) is probably bad. Get an ohm meter and read the resistance directly at the pot terminals (looking into the pot) (before taking the pot apart). If you get a infinite reading (or in the thousands of ohms), the perk heating element is probably bad. On my small pot, that element appears not to be replaceable...but pull the base off and see.
If you pull the base off, you will likely see three components; main perk heating element in the middle of the pot, "keep warm" element - may be covered in braid) skirting the edge of the pot, and finally the thermostat that allows the pot to perk for 7 minutes then opening up the circuit to allow current to both of those elements in series just to keep it warm.
Although I don't have a pot exactly like yours, in my smaller pot, the "keep warm" element (covered in braid) and the thermostat (little button pressed by a spring and screw against the bottom of the pot to sense temperature) can be replaced...go to Goodmans.net.
Why doesn't percolator run long enough
The thermostat in the base of the pot needs replaced...it is the little round thing pressed against the base of the pot. (You can see it after removing the base of the pot.) Pull off the leads and remove the screw holding it in and get a new one at goodmans.net ($10 including shipping...I just got one from them.)
You should take a picture before removing anything to make sure that you get the leads connected up correctly.
You have a main perk element and a keep warm element in the base of the pot. Plus a thermostat pressed against the bottom to sense temperature. Upon plugging in a cold pot, the thermostat reads zero ohms and applies 120 volts all to the perk element. Then when the thermostat senses a high enough temp, it opens and 120 volts is still applied to the perk heating element, but this time through the keep warm element (about 200 ohms or so). So now the perk element although hot is not hot enough to continue perking, just keeps your already perked coffee warm.
On a cold pot, you should read about 17 ohms looking into the pot...on a warm pot (with the thermostat opened up) you will read in the hundreds of ohms.
The pot perks but its just hot water when finished
You need a keepwarm element. Go to repairshack.com. Good luck. Ron
Perks ok coffee lukewarm
After perking the coffee the pot is to switch to a thermostat to keep the coffee warm...that thermostat is probably bad...
Not sure if it is replaceable on those pots...
Would call the Customer service number for the Regalware...
http://www.regalware.com/customer-service/contact-us
heatman101
* Contact
262-626-2121
1675 Reigle Drive
Kewaskum, WI 53040
(google map)
1helpful
It seems to be perking correctly but stops and then starts to perk again and again, this continued until I unplugged it, and also the light to indicate it was done never came on
Your pot needs a keep warm element. the main element works ( perks and perks) The thermostat works ( it turns the main element on and off.) The pot goes on and off because the water is getting cold The problem is the keep warm element. The reason, your pot perk's and it gets hot near the thermo, the thermo turns off the main element. The keep warm element is not on so after a small amount of time the water cools and the thermo turns the main element back on again, thus making the water hot. The K W element is supposed to be on all the time the pot is plugged in, it is instrumental in perking the first brew making it really hot, the thermo turns off the main element and the K W element keeps the water hot. The K M element is very a easy fix, it is the small looking white rope that runs around the bottom of the pot. Thanks and please ask if you need more help. Go to repairshack.com for the part. Ron
1helpful
Faberware FSU-122 coffee maker does not perk
The problem is the keep warm element. The reason, your pot perc's and it gets hot near the thermo, the thermo turns off the main element. The keep warm element is not on so after a small amount of time the water cools and the thermo turns the main element back on again, thus making the water hot. The K W element is supposed to be on all the time the pot is plugged in, it is instrumental in perking the first brew making it really hot, the thermo turns off the main element and the K W element keeps the water hot. The K M element is very a easy fix, it is the small looking white rope that runs around the bottom of the pot. You have 1-nut and 1- screw to remove. When removing the screw from the main element you must hold the (leg) that the K M element is screwed to so it does not bend and brake off. Take your time and be firm with the pressure you apply to the screw, while holding it with a pliers
Doesn't perk long enough
Hi you have a pot made in China, 1 of 2 things are broken. 1 the thermostat, 2 the keepwarm element. 9 out of 10 times it is the thermo.You can not buy them in the USA. I have a auction on eBay and I cab make the parts out ob USA parts. Mt eBay name is ron622c, you can take a look. Go to Farberware coffee pot parts. Good luck. Ron
5helpful
Farberware 4 and 12 cup percolators stopped making good coffee
I thoroughly cleaned my 4-cup percolator by brewing a couple of pots of plain white vinegar and scrubbing the build-up from the bottom of the pot (and running a couple of plain water brews through the pot after all the cleaning). The percolator now brews hot, strong coffee again!
Top Cuisinart Coffee Makers & Espresso Machines Experts
Marvin
Marvin
David Shaub
Colin Stickland
Colin Stickland
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
