Question about In Microwave Ovens
Our microwave, a (built in cabinet with venting), will tend to shut itself down if we cook something longer than, say, 8 minutes straight. No power, lights on panel out. Then a few minutes later i
Our microwave, a (built in cabinet with venting), will tend to shut itself down if we cook something longer than, say, 8 minutes straight. No power, lights on panel out. Then a few minutes later it powers back up and is ready to go again. We overdid the cycle by cooking another long cooking item right after it came back on, and of course it powered off again, but this time when it cooled off and power up again, it fails to heat the food. There may have been a slight odor coming from the machine as well (electrical). Clock counts down, fan running, no cooking happening, though. Any guesses about what we broke and it might be worth fixing? Unit is less than 2 years old.
Posted by Lonnie on
John
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 124 Answers
Not enough venting. Imagine putting your hair dryer on full and putting it that cabinet. Would your venting keep it cool? Your microwave oven uses about the same current
Posted on Jan 03, 2015
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: Microwave quit
I would suspect either door switches or an intermittent control circuit board, either of which can be repaired. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure over time. I have a text file on my site called "doorsw.txt" which helps in diagnosing and repairing door switch problems. You can find the file via a Google search. It will help you check and replace the door switches if you or an able friend is so inclined. In some cases, the problem is a bad connection or a bad relay on the control board. That's something we see fairly often, and we repair them for only $32.50 nationwide.
Posted on Oct 12, 2006
Anonymous
  • 17 Answers
SOURCE: Microwave turns on, but no heat or turntable movement
The problem is that the magnatron is not getting power. Chance is that if could be a bolwn fuse inside the unit. If the fuse don't fix it then that leaves the charging diode, capacitor or the magnatron, or high voltage xformer of which without technical epertize I would not recomend attempting to replace. good luck
Posted on May 14, 2008
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: Microwave Oven Does Not Start Cooking
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
If yours is not shown at the parts site or manual site linked above, Please reply back with your brand and model number so we can help you.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Posted on Dec 25, 2008
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: Microwave stopped heating, evenything else works
Posted on Jan 10, 2009
Anonymous
SOURCE: Microwave turns on and counts down but won't heat up/cook
Ok just figured this out! It is a problem with the alignment on the lower door switch. I took the cabinet off and lifted up on the door switch slightly and voila! It works. You could probably fix this without taking it apart, just lift up on the door ever so slightly. I hope this works for you.
Posted on Mar 06, 2009
Our microwave, a Summit OTR 24 (built in cabinet with venting), will tend to shut itself down if we cook something longer than, say, 8 minutes straight. No power, lights on panel out. Then a few...
Sounds like the electronics overheated. You'd have to pull it and examine the insides to see what has gone bad. It could be pretty much anything.
Dec 20, 2014 | In Microwave Ovens
What do i do after my microwave overheated and shut off?
they have a built in overload thermo cut out when it is on for a long time it will cut out cool down and should be ok to use again
May 28, 2012 | Emerson Microwave Ovens
We purchased a home with the built in model mc0153sf serial # DJ07X01113. we do not have a operators manual. the microwave shuts down when we do a ...
Yes! if the microwave does not have proper ventilation it will go into shutdown, causing it to over heat. The thermal fuse will open if to much heat is detected and can take 30 minutes or more to reset before you can use it again.
Mar 18, 2011 | Microwave Ovens
Tappan TMV151FS over range microwave starts to work and then dies
Never run the microwave without a load (something to heat)!!! That kills the microwave generating parts.
Sounds like a 'thermal' protect switch is activating after running. Make sure that (if the unit is mounted in a cabinet) that there is sufficient space around the unit for proper air flow and that nothing is blocking the vents. Try setting it on a counter top and heat something. If it works properly and doesn't shut off, the venting space is the problem. You may have to have the cabinet that it sits in redesigned for more clearance.
Aug 19, 2009 | Tappan TMT104E1 Microwave Oven
Magic Chef MCD11E3W Just Dies While Cooking
There is an internal cooling fan. Sounds like your s has failed and its thermal cut out is turning it off. Take it for professional repair. You can't open microwaves as they have special security screws, plus there is high voltage and dangerous compounds plus the radiation itself.
Feb 13, 2018 | Magic Chef CMV1000B Microwave Oven
Shuts itself off mid cooking cycle -- as if unplugged; then after 5 minutes or so turns itself back on as if it was just plugged in (forgetting all previous settings)
If you just put the fan blade back on, it will almost certainly fall off again.
The best bet is to slightly rough up the contact area of the shaft with sandpaper and use a little super glue to hold the blade assembly on the shaft, and let it set a few minutes before using it.
I always recommend that you use the hood vent exhaust fan when cooking on the stove top to keep heat, steam, and grease out of the controls.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
May 20, 2009 | GE Profile Spacemaker Over-the-Range...
Daewoo built in microwave..when making popcorn or anything that steams a lot, like bacon, it shuts itself down and stays off completely for about 15 minutes...then comes back on like nothing happens,...
Your microwave has a Humidity Sensor and is designed to shut down when too much humidity collects in the microwave. It will start again once humidity level has decreased. Wipe down the inside of your microwave often. If there is already moisture in the unit before you cook pop corn, you're just adding more humidity to it. If this continues to be a problem, I would contact the manufacturer for resolve. If you found any of these suggestions helpful, please rate my solution. D. Lange
Apr 29, 2009 | Microwave Ovens
Over the range MV Oven shuts down from heat
it is triggering the overtemp switch. try to check the vent outlet, it could be clogged with dirt. or the cooling fan of the magnetron is no longer running. could be stuck up because of not being used for a long time.
Feb 20, 2008 | Microwave Ovens
Maytag MMV5165BA Over The Range Microwave
We had this problem. It was installed improperly - to recirculate instead of to vent.
Sep 07, 2007 | Westinghouse WST3504 Microwave Oven
Shuts off after cooking a few minutes
Since it's under warranty, I would check with MayTag or a local Maytag-authorized servider: http://maytag.com/support/service_parts.jsp
Apr 23, 2007 | Maytag MMV1153A Microwave Oven
Microwave Ovens Logo
187 people viewed this question
Top In Microwave Ovens Experts
William Miller
William Miller
gbob59
Are you an In Microwave Oven Expert? Answer questions, earn points and help others
