Question about magicJack pc to phone, free local & long distance calling, magic jack voip phone
Has dail tone no calls out - magicJack pc to phone, free local & long distance calling, magic jack voip phone
Posted by candy varela on
C. David Graves
    Novelist:
  • 69 Answers
Is your Magicjack plugged into the wall power thru a power module? Try plugging the magicjack directly into a USB port on your computer. If the magicjack work now, then you have a bad power module.
I had the same problem. My Magicjack was plugged into a wall socket. First the dial tone became inconsistent, then I could no longer make calls out, then it died completely. I plugged the MJ into a USB socket on my computer, and it then worked nomally.
Problem:
The problem is in the seperate magicjack power supply module.
When the magicjack is plugged into your computer USB port, it is getting power directly from the 5 volt source in the USB port.
In order to use AC wall current to power the magicjack, a power converter module is needed. That module contains a transformer and rectifier that coverts 115V AC into 5V DC. It is that power converter module that is failing.
Tech section:
I decided to trouble shoot the problem. I measured the 5V output of the power module to be only 3.5V. I took the power module apart to figure out why it failed. I found two 220uF 10V capacitors that were labelled "Low ESR" (C8 and C9). I measured the ESR of these caps and C8 measured 1.5 Ohms. I replaced that cap and it fixed the problem. Output voltage restored to 5V. These electrolytic capacitors do not fail suddenly, they gradually deteriorate. The output voltage of the Magicjack power module will drop gradually until it hits a critical level. The MJ will start to behave sporadically, then it will die completely.
Solution:
I do not recommend repairing these power modules. I did it out of curiosity. These modules are very cheap.
Magicjack is aware of the problem. To contact them, go to www.magicjack.com and go to "support". They will ship you a new power module for about $5.50. Some people have reported that the replacement modules from Magicjack are no better than the originals and have had repeat failures.
Also, consider getting a power module from another source. There are lots of AC to USB power converter modules available on Ebay for only a few dollars. Search Ebay for "magicjack power adapter".
has dail tone no calls out - dail-tone-no-calls-out-mbz13odsyguuiirp1214tyyc-2-0.jpg
Posted on Dec 25, 2014
No dail tone cant call out , and try to call in ,line give busy
Is there dial tone at the base unit? You likely will need to replace the battery ...
Jun 19, 2010 | Uniden 5.8GHz Expandable Cordless Phone...
I can not send a fax with samsung scx-4521f
do a simple test. press the onhook button to you hear dail tone. try key in your mobile number and see if you got the call.
if all the above is yes there is no issue with the modem.
if you did not hear any dail tone. check your phone line is it working fine.
make sure that your phone line is not hunting line. fax machine does not work with hunting line. only direct line.
May 18, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Our company has a Panasonic kx-t7731 main line has no dail tone.
On that phone, press PROGRAM the button and dial 01 STORE.
Press program again to exit programming.
It's not likely you'll be needing the Group Log In/Out button.
Carl
Mar 12, 2009 | Panasonic KX-TA824PK Phone
2 beeps, no dial tone
hand set no dail tone cant all out on the hand set due to no dail tone
Dec 05, 2008 | Uniden Cordless Phone
No dail tone
Check the cor and cos setting of the phone It shold have the permissions to call outside
Dec 02, 2008 | RCA 25414RE3 Corded Phone
Home phone
my phone has a dial tone but wont dial out or recieve calls.
Sep 23, 2008 | Motorola Mobility AT&T Prepaid Free2Go...
No dailing tone
Panasonic Phone kx-tg8231b
it rings but it i have no dial tone can not call out and when i answer it cuts the person off calling
does not show who is calling on the id does not show missed calls or messages left
Jul 06, 2008 | Lands Phones
VTECH VT-2406 TONE- PULSE SETTING ?
http://www.vtechphones.com/vtechui/support/manual.cfm?manualID=373
Jul 03, 2008 | Vtech VT-2406 Cordless Basic Analog
TC1200 TONES/PULSES
There is usually a switch to change it from dial pulse to touch tone.If there is no switch check your user manual to see if there is a screen option.
tk46
Jun 19, 2008 | Panasonic KX-TG1033S Cordless Phone
magicJack pc to phone, free local & long distance calling, magic jack voip phone Logo
124 people viewed this question
Top magicJack Computers & Internet Experts
 Russ Hill
Russ Hill
C. David Graves
Tom Chichester
Are you a magicJack Computer and Internet Expert? Answer questions, earn points and help others
