Question about Jura Capresso Impressa X7 Espresso Machine
How do I fix steam nozzle?
When pressing button for steam or hot water only get a thin stream of cold water. Many thanks for any advice, cheers.
Posted by Simon Egglestone on
4 Related Answers
Anonymous
SOURCE: No milk,or steam coming from cappucinno nozzle
If you pull the cappacino component off. The black plastic thing at the end of the metal tube (where the cappacino component's attached to) can be unscrewed by rotating it with your hand. You can clean it with a brush and a thick needle to clean the hole the make sure that it's not blocked. After that just screw it back on and reattach the cappacino component.
Posted on Jan 09, 2009
Tushar
  • 9 Answers
SOURCE: Changed Claris Filter-now says
Fill your water tank with Warm Water and then try a few times. Keep Patient and Keep trying for some times and it will work.
Posted on Oct 16, 2009
Anonymous
  • 6 Answers
SOURCE: the steam nozzle has broken
Yes you can but it is very hard to get inside the front of the machine if the tube has come off in the front panel, if it has come off one of the solinoids in the right hand side of the machine it is easy to put back on also check that the steam nozzle is not blocked with old milk it will cause the pressure to blow off the tubes
Posted on Jun 26, 2010
Monty
SOURCE: Changed Claris Filter-now says "fill system/press steam"
I have had an S9 for 8 years now and have had it refirbished twice in its lifetime. I am convinced that the Claris Water filters cause this problem in that they can creat to much resistance or air and the system becomes water starved.Try taking out the filter and running steam for a couple of minutes. If you see water coming through, you most likely have a bad filter. moving forward, i am leaving the filter ourt and running the system in the DeCalc mode. I will have to decalcify the system routinely now but its worth eleviating the filter headache.
Posted on Jan 03, 2012
Water, not steam from the nozzle
Most likely a faulty valve the lets the water come out before building the steam pressure. I have not seen a repair manual but it is not that easy to replace he valves. The valves come as a set and are made of plastic. Not that expensive but you will need to open the unit completely to replace them.
Nov 14, 2011 | Krups XP2070 10 cup Coffee Maker/15 bar...
My coffee machine cva610 says descale expel air. It won't allow me to make any more coffee.
If you don't have a manual I hope this helps. You can make coffee without "Descale"ing it but it is recommended you don't go too long without doing it.
- Make sure that the filled water container is in the appliance.
- Turn the program selector to "On" with lighting and place a container under the hot water spout and another under the steam spout.
- Press the hot water button, turn the steam selector counterclockwise and dispense hot water until it flows in quiet, continuous streams.
- Press the hot water button again. Turn the steam selector clockwise to o, to turn off the water.
Regards,
Dave - Avalonxls at att dot net
Feb 09, 2011 | Miele CVA610
Window shows "Expel Air" message.
Fill the water tank.
- Turn the program selector to "On with
light" and place containers below the
hot water dispenser and the steam
nozzle.
and let water run out until it streams
steadily.
Turn the steam selector to "o" to shut
off the water.
ENJOY YOUR COFFEE
Jan 15, 2011 | Miele Coffee System
Recently bought a house that has system CVA615. Hasn't been used a dozen times they said - so I cleaned per instructions. It now says "hot waster - expel air". Have done everything book said...
When selecting "Hot Water," can you hear a pump working (usually a strong buzzing sound)? If you do, then water path may be blocked or pump itself is jammed. A jammed water pump still makes buzzing sound. May be stuck from not using, for long period of time. Especially, in hard water areas.
Nov 04, 2010 | Miele Coffee System
The machine screen reads "ventilate". I open the knob of hot water but it doesn't fix it. What should I do?
Press the button to switch from steam to hot water, then push in on button, if that works then the tap rod assembly needs to be replaced, also check the ens of the steam nozzle, male sure it is not blocked.
Apr 30, 2010 | Gaggia Titanium Espresso Machine
Steam nozzle not working
Check the end of the steam valve, if that is not blocked, check where the wand connects to the valve, on some models they inserted a teflon piece that was supposed to hep the machine with steaming but that gets blocked, remove and throw away.
Apr 16, 2010 | Saeco Royal Professional Espresso Machine
Miele CVA610 error reads expel air but when we do as manual suggests (run hot water & milk frother) no water comes out.
If this doesn't do it for you, you are doing it wrong!
Oct 06, 2009 | Miele CVA610
I have a miele cva620 ind it displays expel air.. what shall i do? how can i do it?
FIll the water tank.
Turn the program selector to "ON with light" and place containers below the hot water dispenser and the steam nozzle.
Press the hot water button, turn the steam selector counterclockwise and let water run out until it streams steadily.
Turn the steam selector to "o" to shut off the water.
That should solve the problem
Jun 25, 2009 | Miele CVA615 Espresso Machine
Descaling
(Button 26 is the right-most one (2 intersecting
ovals.)
From the Manual:
Press the button (26) for at least 5 seconds to
select the descaling operating mode; the LED
emits a fixed light.
• Direct the steam nozzle (14) toward the drip
tray.
• Position a vessel of adequate capacity under
the steam nozzle and turn the hot water knob
anticlockwise (16). The appliance starts an
automatic descaling cycle with pauses preset
by the manufacturer and managed
automatically by the appliance.
• At the end of the cycle, the flow of the
descaling solution is shut off and the 5 buttons
start flashing simultaneously.
• Turn the knob of the hot water nozzle (16)
clockwise to OFF. In this case, also the warning
light (27) flashes.
• Rinse the water tank and fill it with fresh
drinking water.
the steam nozzle and empty 2/3 of the
contents of the water tank by turning the steam
knob (16) anticlockwise; to shut off the flow,
turn the knob (16) clockwise.
• Let the appliance heat up and empty the
remaining contents of the water tank by turning
the steam knob (16) anticlockwise; to stop the
flow, turn it clockwise.
HTH
dave
Aug 14, 2008 | Gaggia Syncrony Compact Coffee...
Ventilate
I fixed my ventilate problem! After 2 days of utter frustration and pushing many buttons, I read another guest comment about resetting to factory settings. Push the up button under the small coffee icon. It should say factory setting with the asterick next to it. Push OK. Then push "yes" for factory settings. Then my machine started working again! Hallelujah! It erased my personal coffee cup setting, but who cares.
Big thanks to the person who posted their solution on Dec. 2007.
Jun 11, 2007 | Gaggia Titanium Espresso Machine
Jura Capresso Impressa X7 Espresso Machine Logo
93 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
markybean
Level 1 Expert
ThaMp3Doctor
ThaMp3Doctor
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
