Question about Canon PIXMA MP530 All-In-One InkJet Printer
Loose screw jamming paper in Canon Pixma MP530 printer
Small screw has fallen into the left side (facing printer) rear paper feed of MP530 printer. A4 sheets get stuck on this side. How to get into printer to extract the screw
Posted by pandf on
  • pandf Jul 17, 2009
    A brilliantly simple and practical solution. I ended up drilling a hole in a small fridge magnet, attaching a piece of wire to it. Using this it took just 30 seconds to fish out the screw. Problem solved. Many thanks
Anonymous
    President:
  • 1,185 Answers
Go buy a magnetic retriever from your local hardware shop they are very cheap.
Make sure you get a slim version
Either that or turn the printer upside down and get someone to whack it on the bottom with the palm of their hand as you hold it
What goes in must come out
Posted on Jul 06, 2009
I have a canon MP810 it is coming up with error code 6B00, what does this mean ?
You probably have something stuck in the paper feed or under the print head.
First try moving the print head left and right with the printer off. If that doesn't work then, Try looking for jam in the paper feed and specifically under the rollers. A small piece of paper or other debris, like fallen paper clip, staple. postage stamp are things I have seen stuck in printers that cause jams and error codes.
If these solutions don't work, post comment here.
j
Feb 21, 2011 | Canon PIXMA MP810 All-In-One InkJet...
Canon PIXMA MP530 All-In-One InkJet Printer Canon mp530 error 6a00
The 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.
Clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like
Dec 15, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Will not print because paper always jams
Perhaps there is paper still jammed inside the printer that you cannot see (or little bits from a previous jam)
1) Turn off the power
2) Disconnect the power cord and USB cable
3) Open the rear cover and see if paper is jammed inside the cassette area. Gently remove any paper and make sure no little bits of paper are left inside
4) Open the scanning unit (printer cover) and check that no paper is stuck internally. Be careful not to touch the components inside the printer.
5) Reattach the power cord and USB cable
6) Power On and retry your print job
Dec 21, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Paper feed jamming, both front and auto rear feed, I'm using plain a4 paper. Can't print out at all as the paper just won't feed in
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
toi-i-25
Jul 25, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canon Pixma iP 1500 is not feeding paper correctly, pulling it on the right side but not on the left.
If the feed roller in the back wobbles a lot, the end could be broken, but usually I find that something has fallen in the back stopping the paper. The best way to look for something fallen in is to use a flashlight and small mirror.
Jul 12, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Paper jammed but no paper is jammed.
Sounds like something has fallen into the paper path. Use a flashlight and small mirror to look down the slot where the paper goes. You may have to use a straightened paper clip or the like to help remove the obstruction.
Jun 26, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Canon mx300 printer feeder pulls unevenly causing paper jam
the left side of the printer pulls the paper causing the printer to jam when trying to print
Apr 03, 2009 | Canon PIXMA MX300 All-in-One Printer
Paper feed
Your printer is politely asking you to please get a torch, and open the lid of unit and thoroughly check inside all over for a tiny jam of paper or something else. I am willing to bet you will find some jam. I would also switch it off, and wait a while before turning on and printing again. Good luck
Aug 31, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
164 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
