Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
SOURCE: sony kv-32s26 32 inch tv
Could also be faulty Power supply. If Proper 110 V is not generetaed by SMPS, the above symptoms appear.
SOURCE: black screen in middle of picture
go tothe menu, caption, take it off the text mode. this should solve your problem
SOURCE: picture in picture problem
When you use the Time Warner Digital box, you're using the tuner inside that box rather than the tuner inside your TV to select a channel. Picture in picture TV's have two tuner's inside so you can view two channels, but they can only tune the analog channels from your cable company, and only if it's hooked up in a manner that will permit this to happen.
So you only have one digital tuner (the Time Warner Box) so you can only view one channel at a time even though your TV supports Picture in Picture.
It MAY be possible to have limited use of the PIP if you connect your TV in a different way. Your Time Warner box is most likely connected to your TV set with composite cables, those are the Yellow, Red, White cables. If you buy a coaxial cable splitter and split the cable before it goes into the Time Warner box you can then run a coax cable into both the Time Warner box and the coax input on your TV. This would allow you to tune the analog Time Warner channels with both of your TV's tuners. In my area I think the first 60 channels or so are still available in analog, but there is no way to watch any of the higher premium channels without the Time Warner box.
If you go through these steps and you select the coax input on your TV your PIP will work on the lower channels. It MAY be possible to tell your TV to display the input from the composite cables on one of the PIP screens and the input from the coax on the other, but I kind of doubt it.
I know this sounds complicated and if you're not familiar with the way all this works it is complicated. The reason lots of people won't respond to this kind of question on this site is because there is no easy fix and by trying to help I run the risk of getting a bad rating. I don't get paid for this, I just like trying to help, so if I have not explained this in a way that's helpful to you please ask some additional questions before you give me a bad rating. Thanks.
SOURCE: 32 inch R.C.A T.V
FPA lock stands for Front Panel Access lock similar to Parental Control/Child lock - it indicates that the buttons on the front of the TV are locked so that it cannot be operated accidentally by young children.
You would need to use the remote to deactivate this security feature. Normally, you would go into the Parental Controls menu and turn off the FPA lock.
If for some reason a password was used, then you would have to enter that password since without it you can't get into the Parental Controls menu.
On some versions, you can press "Menu" on the front panel and "Vol -" on the remote simultaneously for 3 seconds to clear the password. in others, it would require that you press and hold at the same time the Vol < button on the front panel and CLEAR button of the remote control for about 5sec. You would need to enter a new password the next time you access the Parental Control Menu.
Usually, steps involve are explained better in the user's manual which is available at the RCA (Support) website. You would need to enter the exact model number of your RCA TV.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
SOURCE: Ct-36g23
In older CRT televisions the horizontal power supply can start to degrade causing the picture to shrink.
Take it to a qualified repair man to have him replace the particular components that are starting to die. This repair will require identifying the particular component and replacing it.
Often times just finding the bad component can take hours of troubleshooting by a skilled technician.
Tho, before you take it in try ruling out one simple issue like bad mains voltage. Try plugging it into a different outlet in a different part of the house.
Problem with Vizio L32 32 in. HDTV LCD Television
how do i turn off the orange light on the vizio tv, it won't go off after the tv is turned off?
Posted by
meg_car on Jul 08, 2009
Service by: mjsazon
