Question about ULINE U Line Combo 2000 Series C2275DWRS00 24" Built-in Combo Ice Maker/Refrigerator Drawer with 5.0 cu. ft. Total Capacity, Ice Maker, 10 lbs. Ice Storage and Digital Touch Controls: Stainless Steel
Ice cube stick on the box,how can I get rid
Open the cover
Posted by alllen on
Perkins Byrd
    Scholar:
    New Friend:
  • 102 Answers
Try wiping the sides with a thin coat of non-stick spray, like Pam or something. Be sure the sides are dry before doing this.
Posted on Nov 22, 2017
The Refrigerator's ice maker makes ice, but will not eject the ice. Have tried to reset the ice maker but will not eject, any ideas?
The ice maker has heater that thaws the ice cubes a little before they are ejected. This keeps the from sticking to the form.
Jun 26, 2015 | Kenmore Refrigerators
Dumping ice
If heater element is open the newly made cubes will stick to the tray and not be pushed out by the fingers doing the ejecting.
Apr 08, 2014 | Whirlpool 2198597 Ice Maker
English instructions for saivod fhs186 ice maker
DO THE BASICS:
Change the water filter
Add ice machine cleaner and go by the directions.
What should be kept clean?
There are 5 things to keep clean:
1. The outside cabinet & door.
2. The ice storage bin.
3. The condenser.
4. The ice making system.
5. The ice scoop.
The ice storage bin should be sanitized
occasionally. It is usually convenient to sanitize the
bin after the ice making system has been cleaned,
and the storage bin is empty.
A sanitizing solution can be made of 1 ounce of
household bleach and two gallons of hot (950F. -
1150F.) water. Use a clean cloth and wipe the
interior of the ice storage bin with the sanitizing
solution, pour some of the solution down the drain.
Allow to air dry.
How to clean the condenser.
The condenser is like the radiator on a car, it has
fins and tubes that can become clogged. To clean:
1. Remove the kickplate.
2. Locate the condenser surface.
3. Vacuum the surface, removing all dust and lint.
Caution: Do not dent the fins.
4. Replace the kickplate.
Winterizing
1. Clean the machine as explained on the next
page.
2. Turn off the water supply.
3. Drain the water reservoir. See page 24, Spray
Pump Repair and follow the instructions to remove
the pump hose (step 2, bottom hose only).
4. Disconnect the incoming water line at the inlet
water valve.
5Remove control box cover and turn the timer
into the harvest cycle.
6. With the machine operating, blow air through
the inlet water valve; a tire pump could do the job.
7. Drain pump models should have about 1¤2 gallon
of RV antifreeze (propylene glycol) poured into the
ice storage bin drain.
Note: Automotive antifreeze must NOT be used.
8. Replace control box cover. Switch off and
unplug the machine.
CUBE ADJUSTMENTS
There are three items that may be adjusted: Cube
Size, Harvest Time, and Bin Level. Note: Cube
Size and Harvest Time adjustments should only be
done by a qualified service person.
Cube size control.
The cube size control should only be adjusted to
bring the cubes to the correct shape, the overall
size cannot be adjusted. Try to adjust the cube
size control when the ice machine is in the harvest
cycle, or in the first 10 minutes of the freeze cycle.
1. Open the door and remove the control box
cover.
2. Locate the cube size adjustment screw, and to
make fuller cubes, turn the screw clockwise about
1/4 turn. This will make the freezing cycle longer.
3. To shorten the freezing cycle and make cubes
that are not as full, turn the adjustment screw 1/4
turn counterclockwise.
4. After the next freezing cycle, the cubes should
have responded to the adjustment, if another
adjustment is required, do it early in the freeze
cycle.
Diagnostic Codes
Code Description
F - - - - - - - Freeze Cycle
F flashes- - - - Freeze Cycle is Pending
H - - - - - - - Harvest Cycle
H flashes- - - - Manual Harvest
b - - - - - - - Bin is Full
C - - - - - - - Clean Cycle
L - - - - - - - Board Locked
d - - - - - - - Test Mode
O - - - - - - - Off
E - - - - - - - Self Test Failed
1 flashes- - - - Max Freeze - Retrying
1 - - - - - - - Max Freeze Time Shut Down
2 flashes- - - - Max Harvest - Retrying
2 - - - - - - - Max Harvest Time Shut Down
3 - - - - - - - Slow Water Fill
4 - - - - - - - High Discharge Temp
5 - - - - - - - Sump Temp Sensor Failure
7 - - - - - - - Discharge Temp Sensor Failure
8 flashes - - - Short Freeze - Retrying
8 - - - - - - - Short Freeze - Thin ice
All 4 Upper Lights Flashing - Unit Remotely Locked Out
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 14, 2010 | Scotsman Ice Maker CM3 30inW Cubed Ice...
My scotman model sce170a1a.goes into harvest to
That has to be a faulty control wouldn't you think?
cover.
cycle.
Feb 04, 2010 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Ice maker trap door does not close tightly, ice cubes become one big cube and water drips from the ice cube trap door. need some adjustment to this door so cubes do not melt and water run out of storage...
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
There is a solenoid that operates the door that could be sticking.
The hinge on the door could be broken or the bracket it goes in could be broken.The spring could also be off or broke. You'll have to look to see what's wrong.
Sep 23, 2009 | Refrigerators
Ice maker makes ice but comes out wet
Your ice maker may have an adjustment if behind the front cover has a set screw to plus or minus the amount of water. If it is controlled with a control board it will need to be replaced. Now if for some reason the water control valve on the rear of your refrigerator is sticking open or leaking too much water that may be the problem. The replacement Ice Maker part number 732489 and appears as a kit with the water valve included, Thanks, Sea Breeze
CLICK HERE=> http://appliancepartsse.blogspot.com/
Aug 20, 2009 | Whirlpool ET4WSKXS Top Freezer...
Ice maker dripping water fusing ice cubes
The dual water valve (solenoid) that open and let the water from the line when the ice maker calls for it, is leaking and needs to be replaced.
Aug 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice cubes melting and then sticking together
If you have dispenser to get ice or water, there is a cover to it that opens and closes as you ask for ice. If that mechanism is not working it stays open all the time and causes your ice to melt because cold air scapes. You should be able to replace that yourself. Sears sells that part. It is not very expensive. There is a cover over the dispenser pannel. It should right behind it
If you Agur that suppose to turn the ice to dispense, that could burn up too because the agur can not turn all chunk of ice
Aug 01, 2009 | Refrigerators
Refrigerator not making alot of ice cubes
a bad valve will make them stick togather and sometimes hollow but the ge is well known for the back board being bad
Mar 18, 2009 | Refrigerators
Frigidaire gallery side by side is not making ice. When it does on occasion make ice the cubes get stuck in the ice maker before dropping into the holding box
It sounds like you need to adjust the size of the ice cubes.
If they stick together in a long row, to much water, and then of course if they are too small that is also a problem. All you have to do is remove the outer cover of the icemaker and look for the set screw. It will stand out from the others. and be marked with a Plus and a Minus sign. Whichever you are having the problem with, adjust accordingly. I would try 1/4 turn increments. See how that works after One day and then re-adjust as needed.
Hope this helps you out.
Bill
May 09, 2008 | Frigidaire Refrigerators
ULINE U Line Combo 2000 Series C2275DWRS00 24" Built-in Combo Ice Maker/Refrigerator Drawer with 5.0 cu. ft. Total Capacity, Ice Maker, 10 lbs. Ice Storage and Digital Touch Controls: Stainless Steel Logo
1,434 people viewed this question
Top ULINE Cooking Experts
Tom Chichester
ray gallant
Andrew Taylor
Andrew Taylor
Are you an ULINE Cooking Expert? Answer questions, earn points and help others
