Question about ULINE U-Line 1175BEVS-00 1000 Series 24" Reversible Door Beverage Center Refrigerator with Dual Cooling Zones in Stainless Steel 1175BEVS-00
Unit will not cool
Compressor runs but unit will not cool. E45 message flashes alternately with temperature in digital display.
Posted by Rick C. Ellis on
I meant the AC does not cool
Make sure the mode is set to freeze and temperature is set to below the room temperature.
If it is a split system, check the outdoor unit whether it is running. If it is running, see if you can reach and feel the temperature of the pipes connecting between the indoor and the outdoor unit. It should be cool.
If it is not cool, you may need to get somebody to check the refrigerant.
May 22, 2014 | Dometic 57915531 Air Conditioner
A/C runs fine for 7-8 minutes, then shuts off.
AHX18MEV
4 - 12
[8] SELF-DIAGNOSIS FUNCTION
1. Indoor unit
(AH-X18MEV, AH-X18MEV-1, AH-X24MEV, AH-X24MEV-1)
To display the self-diagnosis, hold down the AUX button for over 5 seconds on the indoor unit when the indoor unit is not operating.
• The operation lamp (red), timer lamp (orange) and Super jet lamp lighter) flash to indicate the information of malfunction.
(Display of self-diagnosis result)
The operation lamp (red) and the Super jet lamp (green) flash in synchronization with the timer lamp (orange).
(AH-XP18MV, AH-XP18MV-1, AH-XP24MV, AH-XP24MV-1)
• The POWER CONSUMPTION indicator indicates the information of malfunction by showing the main category error (number) and the sub-category
error (-number) alternately in 1-second intervals.
Example: Compressor high-temperature error
Remark
May 11, 2013 | Sharp Heating & Cooling
My Hitachi air con (heat/cool) unit is PC-P1H is showing the message H.01 05 and it says the word
Switch it all off. Switch on the outside unit then the inside unit and reset the clock and temperature settings
May 17, 2012 | Hitachi Heating & Cooling
My air conditioning will not turn on. The thermostat control has only four buttons,two adjusting the temp up or down,one turns the fan on or on auto and the other selects the system cool heat or off. When...
After setting the unit to cool and adjusting the temperature, the compressor should run if the light stops flashing. Check the condenser, if the fan and compressor does not run, check the contactor if it is energized or pulled in. If the contactor is not pulled in there must be no power or the holding coil is open. If the condenser fan is running without the compressor, check your compressor, high pressure switch, and capacitor.
Sep 09, 2011 | Honeywell Heating & Cooling
Of error code on display screen. how do I fix it?
If your control panel displays "OF" instead of the temperature, your refrigerator is in "Cooling Off" mode. In Cooling Off mode, the refrigerator appears to be running normally, but the compressor is off so the unit does not cool. Cooling Off mode is used by retailers to save electricity when the refrigerator is on the showroom floor.
Note: Cooling Off mode is also called Demo mode or Exhibition mode.
Depending on your refrigerator, to remove your refrigerator from Cooling Off mode:
  • Either press and hold the Energy Saver and Power Freeze buttons for 3 seconds
  • Or press and hold the Power Freeze and Freezer buttons for 3 seconds.
The temperature display re-appears after the unit is out of Cooling Off mode.
Aug 21, 2011 | Samsung RS267TD
Unit runs but does not cool.
IF YOU UNIT IS IN FACT A WKL UNIT(DIGITAL DISPLAY) IT COILD BE TWO THING A BAD BOARD THAT IS NOT SENDING POWER TO THE COMPRESSOR OR A FREON LEAK.
ON MAJORITY OF CASES ON A FREON LEAK THE UNIT WILL FORM ICE ON THE COIL, SOME TIMES A LOT OF CONDENSATION ON THE BODY OF THE UNIT AND IT WOULD LOOSE COOLING GRADUALLY UNITIL IT WOULD RUN NON STOP.
CONTAVTTHE MANUFACTURER FOR A BOARD OR ASK FOR A TEMPERATURE DIFERENTIAL TEST TO CHECK FOR A FREON LEAK.
Oct 25, 2010 | Breezaire WKL 4000 Wine Cooler
I just received this air conditioner. Set it up
It sounds like you have a faulty unit, that has a bad built in thermostat. I'd suggest sending the unit back for a replacement, or get a refund, & buy another unit. What you may think is the compressor kicking in, might just be the blower fan. Try raising the temperture as high as it will go, & see if you hear a noise change to quieter. If it does get quieter then the compressor was in & is not working properly. Send it back.
Jul 10, 2010 | NewAir AC-12000E Portable Air Conditioner
Unit does not cool. Original unit was replaced because of defective compressor. Replacement unit worked in store but now does not cool and alternates blowing cool and warm air.
Is this a window unit? Sounds like the compressor may be cutting on and off. That would cause the alternating air temp you are feeling. Make sure the condenser fan is running. If it isn't running head pressure will build up on the compressor until it shuts down. Then the pressure will equalize and the compressor will kick on again. Also check your filters and the condenser coil to make sure it is clean. Let me know what you find.
Jul 08, 2010 | Frigidaire Heating & Cooling
THE UNIT DOES NOT COOL ANDY COLDER THAN ROOM TEMPERATURE.
does the compressor run ? if so you could have a low refrigerant charge, a sealed unit resrtiction, leak or defective compressor.
Apr 30, 2010 | Haier HVUE08A Wine Cooler
Temperature display and "Cool" light flicker and click
It has an electrical problem, first. You (and I) won't know about needing freon until the compressor is running.
Jul 23, 2008 | Kenmore 72055 Air Conditioner
ULINE U-Line 1175BEVS-00 1000 Series 24" Reversible Door Beverage Center Refrigerator with Dual Cooling Zones in Stainless Steel 1175BEVS-00 Logo
42 people viewed this question
Top ULINE Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
john h
Are you an ULINE Refrigerator Expert? Answer questions, earn points and help others
