Tv is stuck on stand by
Tried everything
Posted by anne mclaughlin on
stasi78
    New Friend:
    Problem Solver:
  • 14 Answers
Try using lequid soap applied on stand to make it slick
Posted on Dec 18, 2014
CANN NOT SEEM TO MOUNT THE TV ON THE STAND PROPERLY
Mounting instructions are in with the setup instruction for the TV or TV Stand. Did a mount come with the stand, or is it a separate add on to the stand? In some cases TV Mounts do come as an option?
Feb 26, 2014 | Whalen Furniture Austen 3-in-1 TV Stand...
My Sony KP-51WS500 is stuck in Stand by mode
Have you tried unplugging the TV for a few minutes? if it's some kind of computer error, unplugging it will allow the error to clear and possibly allow the TV to work again. Just an idea.
May 22, 2010 | Sony KP-51WS500 51" Rear Projection...
I have a Hitachi it is stuck on stand by. Cant
Hi I have same problem as you but with different brand of tv, now is all good, if you open your back tv see there board connect to your on /off button on tv or find where is on/off button on your tv, try follow where is the wire going to the board,there is 3 cappacitor in mt tv said 470 uf 25 V your tv could be different size. the capacitor doesnt look bulge or bad but i just change it cost me aus $ 2.10.and work straigh away. hopely this help.
regards.
Apr 30, 2010 | Hitachi 42HDS69 42 in. Plasma Television
Tv stuck on stand by.thought remote was playing up .how can i get it to switch on
Reboot. Turn everything off. Important: unplug from electrical outlet. Power is still feeding into appliances when they are turned off. Wait 10-20 seconds. Plug everything back up and restart.
Mar 13, 2010 | Atec Dusty Baker on Hitting Interactive...
TV stand stuck to dresser
Try spraying a little water near the feet and apply heat from a blow dryer. Not too much don't want to melt anything.
Nov 23, 2009 | Televison & Video
SONY Bravia TV stuck on stand
Put some ice on the bag put it in the stand for a few hours,take the hair dryer max setting put some heat on the plastic,might loosen the moistster,and heat compound in there.Will able to lift.
Aug 24, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
TV won't turn on or off. Stuck in stand by mode
its a power problem on the electronics board need an tec to open the tv and slve the problem
Aug 17, 2009 | Gateway LCD26TV 26 in. Television
Tv stand
you should try Ikea...they have everything :D
Aug 16, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
LG 32LB75 TV stuck in stand by and won't switch on!!
TV currently on stand by and won't some back on. Only way to switch it if is by unplugging it, which I've tried, but goes straight back onto stand by.
Mar 24, 2009 | Televison & Video
ILo tv stuck on stand-by
there is some internal problem, maybe you must reheat the IC's inside or there is probably defective parts. Try if it oscillates if you turn it on by monitoring the collector voltage and it must be around 100 to 135 volts.
Jul 30, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
