I have filled the tank like it says to. when Idle it says (DREGDRAW. MISS.)
SOURCE: Saeco Primea Cappuccino Touch Plus Coffee Maker fill water tank
The Primea do not have a float, it have a magnet and inside the machine there are a printed circuit card, this send a signal to the powerboard.
SOURCE: No power to my Spidem Trevi Digital Coffee machine
Although it may be a different problem completely, most of these failures are caused by a thermal fuse that has opened. They are positioned close to the heating element and serve to prevent fires in case the control of the heater element fails. Unfortunately, they often fail for no reason at all (except being poorly made in China) and are welded into the circuit (solder melts at too low of a temperature) making them nearly impossible to replace at home.
SOURCE: ventilate problem
check hous from tank to steam valve,maybe just plugget out,or your flowmetar is not good any more
SOURCE: spidem trevi digital plus coffee machine not working as it should
it sounds like you need to go into the programing mode. in there you can set the machine so it grinds when you select coffee. at the moment it is pregrinding this is so you can make lots of coffees 1 after the other
SOURCE: CAN NOT MAKE A COFFEE DO NOT UNDERSRTAND THE MESSAGE I GET.
Just try to pour some hot water out from the steam wand after some seconds the veltilate massage will go out.
Good luck
