We've tried printing on correct paper and it was printing fine, then it began printing light. Help!
INK CARTRIDGE REPLACEMENT PROCEDURES
You don't give the make and model of your printer, so I can only give your general rather than specific advice tailored to your printer.
This message probably refers you to the Instruction Manual or quick Start Guide that came with the printer.
This will have been a warning about following the correct procedure when changing cartridges. The manual would probably advise you to run a print head cleaning operation to clear any ink that may have dried due to the fine micro-nozzles in the print head being exposed to the air while you were changing the cartridges. It might then go on to advise you to print an alignment page to enable you to make adjustments, if necessary, to ensure you obtain the optimum print resolution.
I hope this helps
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it. Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can. If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
If the entire page is light, the print resolution setting is too light or Toner Save Mode is on. Adjust the print resolution and Toner Save Mode in the printer properties.
Make sure TONER SAVE MODE is NOT ENABLED!
