Question about Samsung 4.3 cu. ft. VRT Plus , Steam and PowerFoam Front Load Washer
Samsung VRT with a DS or D5 code? Door closes but won't lock
Had load of laundry in machine and it stopped, beeped and said door was open, but actually, the door was locked and would not open. We went through the test mode, and were able while testing, to get it to click open. So, now, we can open and close the door, but it won't lock, and is still showing the code D5 or Ds? Help
Posted by Lydia Reiser on
coetzee_phil
    Habit-Forming:
  • 139 Answers
Sure the error code is not "de"? Faulty door lock mechanism or needs to be released manually.
Regards
Phillip
Posted on Mar 26, 2015
Jorge Rendon
  • Samsung Master
  • 5,420 Answers
Bad door lock switch mechinism or the control board is bad at the emergency door lock circuit? where the wires from the door swtich attache, check ur schematic and will need a multimeter
Posted on Dec 20, 2014
5 Related Answers
Anonymous
SOURCE: door wont lock
door won't lock & shows d5 code what do i need to fix it?
Posted on Jun 09, 2010
caroldon
  • 17130 Answers
SOURCE: I have a front louder
The machine has to reset to bringg tthe lock to release, check the link to the lock settings to make the program complete the cycle and release the lock. Do not force it as you end up damaging.
Posted on Sep 01, 2010
Kludger
SOURCE: door won't close/lock
Just had the same issue. The latch, which rotates up and forward, is spring-loaded towards the rear. If 'tripped' to closed position, it cannot rotate back down until it's carrier/hinge slides slightly forward. I bent a sturdy wire into a long 'U', then bent both ends down (~3/8in) and slightly outward to hook over the latch-hinges and pull both sides gently (its plastic) forward, while rotating the latch downward with a small screwdriver. be careful to keep what appears to be a brown plastic button raised, if it pops down from above the latch. Yes, having 4 hands would help, but the 'U' wire can pull from behind the two outer edges with one finger. Once the latch rotates down, release tension on the 'U' wire and extricate it - problem solved.
Jon (We don need no steenkin manuals)
'Build a more idiot-proof machine, and the universe will build a better idiot.'
"We don't take no s*** from no machines."
Colonel Jason Grant (Walter Koenig), Moontrap 1989
Posted on Dec 19, 2010
kieren lowe
  • 330 Answers
SOURCE: The door on my Samsung Washer won't latch. It then
This means your door interlock has broken & needs to be replaced.There made of plastic this is a very common problem with all brands of front load washer's.
Posted on Mar 14, 2011
richroth
Richard Roth
  • 9472 Answers
SOURCE: Samsung washing machine door won't lock
What is the model number?
Posted on May 21, 2012
Samsung front load washer code d5
The D5 error is actually DS. The code means the washer thinks the door is open or unlocked during the cycle. the problem is related to faulty door locking assembly.There is a switch in back of door, if this fails it wont work. God-Bless!
Nov 06, 2015 | Samsung Washing Machines
Motor won't turn on Samsung VRT Plus WF433B*GJ**
When washing heavily soiled loads, do not overload your washer in order to assure good cleaning results.
To add a forgotten item:
1. Press the Power button.
2. Press the Start/Pause
3. Wait for the door lock light to go out (Immediately).
4. Add the item, close the door, and press the Start/Pause
The door safety state continues for 15 seconds and the cycle is restarted.
ensure thorough cleaning,
To
Try washing bedding, towels, undergarments,
contact using the ActivFresh
GETTING STARTED
1. Load your washer.
2. Close the door.
Z_
Push the laundry into the drum completely to prevent the laundry from being caught in the door or
....... from falling out of the drum.
3. Press the Power button.
4. Add detergent and additives to the dispenser (page 20-21).
5. Select the appropriate cycle and options for the load (page 14-16).
6. Press the Start/Pause
7. The Wash Indicator light will illuminate.
8. The estimated cycle time will appear in the display.
The time may fluctuate to better indicate the time remaining in the cycle.
The actual time required for a cycle may differ from the estimated time in the display depending on the
water pressure, water temperature, detergent, and laundry.
9. Before your washer starts to fill, it will make a series of clicking noises to check the door lock and do a
quick drain.
When the cycle is complete, the door lock light will go out and "End" will appear in the display.
DO NOT attempt to open the door until the door lock light is off. To add a forgotten item, see
"Loading your washer" section (page 13).
When your washer is restarted after a pause, expect a delay of up to 15 seconds before the cycle
continues.
Pressing Power button cancels the cycle and stops your washer.
The pre wash, wash, rinse and spin indicator lights will illuminate during those portions of the cycle
Nov 28, 2013 | Samsung 4.3 cu. ft. VRT Plus , Steam and...
GLTF1240ASO Front Door Won't Lock/Close
Most probably your door lock is damaged. You are not supposed to force it open, you have to wait for at least 2 minutes (or till the lock sign is off) after the wash is over to open the door, never force it.
You can just google your model number and search for parts to obtain it. It is quite possible you can change it yourself. See that the line is disconnected from the mains.
Jun 04, 2013 | Washing Machines
Washer won't stay running error code DS
I am wondering if your error code is DS and not D5, which would indicate problems with the door lock assembly communicating with the control board. Essentially, the control board does not believe the door is closed and/or locked, so it shuts down the machine.
Oct 16, 2012 | Washing Machines
D5 error
Error code D5 OR DS is the same.Its mostly DS which looks like D5. The D5 error is actually DS. The code means the washer thinks the door is open or unlocked during the cycle. The door has to be checked.Is it getting properly close/open.If its getting close/open then the problem is related to faulty door locking assembly. But if its not getting proper close then there is any blockage causing the door to close or the door lock latch is faulty causing this problem.
Hope helps.
Jul 28, 2011 | Samsung WF337AA Front Load Washer
Not sure if this is the right wasing machine that matches ours or not but we are getting a d5 error and don't know what it means
The error code D5 OR DS is the same.Its mostly DS which looks like D5. The D5 error is actually DS. The code means the washer thinks the door is open or unlocked during the cycle.The door has to be checked.Is it getting properly close/open.If its getting close/open then the problem is related to faulty door locking assembly.But if its not getting proper close then there is any blockage causing the door to close or the door lock latch is faulty causing this problem. This has to be checked to confirm the fault.Keep updated with any more queries.Thanks.
Oct 14, 2010 | Samsung WF337AA Front Load Washer
When i turn it on it beeps and the letters d5 show up
hello,
this indication is an error code saying that the door of the washer is not well luck /close
what you are to do to solve the problem is to put off the washer from the power supply then on it again after some time then open then door and close it properly with care the d5 code will be solve
thank you and thanks for using fixya.
Jul 12, 2010 | Samsung WF337AA Front Load Washer
Door wont lock
Dec 18, 2009 | Samsung WF203ANW Front Load Washer
Error Code d5
It sound like a loose or a broken lid switch issue. The lid switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. Good luck!
Aug 21, 2007 | Maytag Neptune MAH9700 Front Load Washer
Samsung 4.3 cu. ft. VRT Plus , Steam and PowerFoam Front Load Washer Logo
974 people viewed this question
Top Samsung Washing Machines Experts
Eric Rotmil
Eric Rotmil
Jerry Greenberg
Jerry Greenberg
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
