Televison & Video Logo
e
eliane zerbe Posted on Dec 18, 2014
Hi guys, well our skyworth tv was just fine in the morning, turn off because the electricity went off as usual, but this time, while i'm trying to turn it back on the skyworth blue screen show up then it fades away to a black screen we still can hear the sound but all we can see is a black screen! anything we can do! or should the tv visit the repair shop ?! help help, and thank you so much
How can I set key lock off on my skyworth tv? All the buttons are not working.
http://www.nekkedmeter.com/news-skyworth-tv-how-to-unlock-339.html#:~:text=Press%20%C3%A2%E2%82%AC%C5%93LOCK%C3%A2%E2%82%AC,factory's%20initial%20password%20is%200000.
SOLVED: How can i unlock the child lock of skyworth tv set ...
www.fixya.com > Forum > Televison & Video
Jun 25, 2013 - Turn on your TV. · On the remote, press the Menu button. The Set-Up Menu appears. · Scroll to the Key Lock function and set function to Off. · Press ... 1 answer
SOLVED: How to Unlock panel Key skyworth LED TV Model ...
Dec 26, 2012 - How to Unlock panel Key skyworth LED TV Model 32E65 Lock Panel ... down cursor to select "panel lock" then select right cursor to switch off ...
Videos as well
https://www.google.com/search?q=skyworth+tv+key+lock+off
1helpful
Stalls losing electric power
How old is the battery & have you tested it?
How is it that a month went by & your using
any vehicle that could let you down?
Why have all issues not been resolved ,as soon
as they started?
Have you checked for codes?
Have you had a professional scan tool on it
& checked data,that has to be done along with
many other checks or tests,unless it's just a battery
issue.
No one can solve any vehicle issue over the internet
There is always more to the story & you need the patient
My sony trinitron is blinking red and won't turn on
THIS IS NORMALY CAPACITORS IN THE POWER SUPPLY THAT NEED REPLACING
1helpful
I have a JVC model HD-52G886 tv. that loses sound.
Replace or have replaced the Audio board in the set----a lot of them fail.
Goodman furnace that was working fine until i went out of town for 4 days, turned off the power, and now cannot get the electric ignition to work [although it did fire up for 1-2 seconds the 2nd tim
You need a heating guy, not electric guy. Most heating serviceman are well schooled in power wiring and if by some chance it is wiring, they can help. But it sounds like a furnace problem. I would need your full model# to help trouble shoot the exact problem.
This only happens in the morning when I get up, the TV will not stay on. When I press the power button it turns on and then shuts off. Sometimes it takes a few times of this before it kicks on but this...
it's almost like it's to cold and needs to warm up or something first, How cold does it get there? I can't imagine it even gets to temps as cold as here. In my experience I've seen T.V's where this has happened and only gotten worse as time went on until one day....It never come on at all. But it wasn't a flat panel either. maybe it's letting you know she's about to kick the bucket. Try warming it up with a hair dryer in the morning first and see if it stays on then, then you'll know at least it temp related. other then that sorry guy
3helpful
TV has been working great for the past 6 years, this morning when turning on the TV nothing happens except the standby light flashes about 9 times on and off. No click like I usually hear when turning on...
Hi Dave,
We have had this same problem twice now - the first time under warranty (no problem) and now currently. The 9-blink error code refers to needing to replace two diodes on the G board. Specifically, D6301 and D6116.
The warranty time, the repair guy came and resoldered the new diodes onto the G Board, reinstalled the board, and was on his way. We had no problems for the next 3 years.
THIS time I ordered the two diodes from Andrews Electronics (www.andrewselectronics.com) am removing the G board myself and taking JUST THE BOARD to a local TV repair guy. This is a LOT cheaper than calling Sears or taking the whole TV to the repair guy. Here are the links to the specific diodes:
D6301 - http://parts.andrewselectronics.com/search/electronic-parts/parts/7/6-500-567-21.aspx
D6116 - http://parts.andrewselectronics.com/search/electronic-parts/parts/7/8-719-081-97.aspx
They are a heck of a lot less expensive than other places and the customer service I received was great!
I hope this helps!!
1helpful
Fridge tripping the electricity
Hi
this sounds like the defrost heater is faulty. because at a certin time the m/c brings on the heater one every 24 hours that is why it is only tripping out at that time.
regards
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
