Question about Compaq Computers & Internet
I haven't tried nothing I want to see if there is away my tablet can connect to the Compaq w17q LCD monitor
SOURCE: Removing the case for a Compaq 7020 17 in LCD monitor
The case has 2 plastic snaps en each side as well as 3 snaps at the top
Use a flat-head screwdriver in the **** between the gray and black plastic. Twist the gray plastic away from the black plastic, and this will snap the part appart
Posted on May 30, 2008
SOURCE: Power supply for Compaq 1501 15" LCD Monitor
arrange the manual from any where with same model and find it .without looking directly i cannot advice anything try to understand
Posted on Oct 30, 2008
SOURCE: Monitor: Compaq TFT5015 Displays vertical lines
Check that the signal cable from the computer is firmly connected and that there are no bent pins in either end. If the trouble continues, the problem is in the monitor itself. Given the low replacement cost, it's uneconomical to try repairing these.
Posted on Apr 17, 2009
SOURCE: Cannot install: HP Compaq WF1907 Wide LCD Monitor Update.
I found in the folder of Hp the file that does the " UPDATES".
So, thanks for the offer to help me, but all is well now with me and the Hp UPDATES.
Regards
Frank
Posted on May 20, 2009
SOURCE: i have a compaq w17q monitor and the osd locked
Hold the menu button in WHILE turning on the power. This toggles the state of teh OSD lock.
Posted on Nov 04, 2009
