CLEANED PIPES AND O RINGS
SOURCE: descaling a delonghi magnifica ESAm04
I had this problem too. The instruction manual says to turn the steam knob only half way counter-clockwise after pressing the button for 5 seconds, but you need to turn it ALL the way to have the procedure start (at least, that was the solution with my machine). Good luck!
SOURCE: hello i have an Delonghi esam
I had this problem until I realised that you need to switch the machine off by pressing the on/off button on the front of the machine first *before* switching it off at the back and unplugging it. This moves the infuser unit further to the bottom and then allows you to take it out.
SOURCE: delonghi perfecto esam 5400 instruction manual. I
A small stone got pretty stuck in the grinder of my Delonghi esam 5400. Anyone knows how to remove it?
SOURCE: how to replace Delonghi magnifica
ha this is the same problem i had just last week at a customers house with the same machine , the knob does pull off but it is hellish tight and you feel like the valve is about to burst through the front of the machine but it does pull off, when fitting the new knob it is a good idea to put some grease over the shaft before pushing the new knob on as it's nearly as hard pushing the new one back on as taking the old one off.
regards
Ian
SOURCE: I have Delonghi ESAM 3300 and grinder runs for
We had excactly the same problem a couple of times recently with a lot of troubleshooting,like adjsusting grinder, reseting the to factory settings, and many more and we end up that it was a problem with pcb control board which lost the preset timing of grinding thus the coffee grinding where about 3-4 sec and the correct one shold be about 8-9 sec. We have here one side which have the control board for your reference.
Two O-Rings. A small Black one and a larger Orange one.
