We have a 2001 Frigidaire clothes washer and latley the agitater only spins to the right and the clothes get wrapped arouind the agitater. The model is FWX 233 RES6. Any help gratfully appreciated
I appreciate your post, Kathy Saalfeld!
From my understanding on permanent press your Frigidaire washer will not spin out enough water. This could be a possible issue with your control panel or sensor within the inside of your washer. You may want to review your drain tube to assure that it is not restricted or kinked. This could be a possible problem with your drain pump or timer. You may need to consult with a professional technician for a proper diagnosis and repair to be performed on your washer. Good luck. -Matt
I appreciate your post, Rachel Kovach!
From my understanding your Frigidaire frontload washer is not spinning the final spinning and the clothes are still wet. If you washer is overloaded it will not spin properly to release the water out of the clothes. Also, a small load will cause your washer to not spin properly. You should additionally check the drain hose to make sure it not kinked or twisted that could cause your improper draining. If all that checks properly it could be an issue with your drain pump, motor, and control panel. I would suggest consulting with a technician for proper diagnosis and repair. This will help avoid unnecessary part purchases. -Matt
