Question about Home
Gazo Rancho Santa Fe Grandfather Clock won't chim
Hello my Grandfather Clock won't chime on the hour at all everything else works great. time, chimes on the 1/4 hour just nothing just not the big single chimes to how many hours. can you please help it has 3 weights, cable driven, tubular chime rods thank you.
Posted by Sally borslien on
srr_robin255
    New Friend:
  • 37 Answers
Check the wires in the back.some times the get corrodes.
Posted on Dec 18, 2014
It wont chime on the hour
Basic assumption... The chimes know what time it is...!!
FORCE NOTHING...!!
From page 10 of owners manual below (MINUTES):
EXAMPLE: Clock chimes at 1:10 but should chime at 1:15.
Step 1: When clock chimes at 1:10 stop the pendulum and record the time of 1:10.
Step 2: Carefully remove the small nut....
(Hour procedure is on the SAME PAGE (10).
WARRANTY INSTRUCTION MANUALS
Apr 19, 2016 | RIDGEWAY GRANDFATHER CLOCKS Ridgeway...
I have a polaris 31 day grandfather clock that is chimming 1 hour and 15 minutes to soon. (Example: real time is 8:45 and it is chilling lime it is 10:00 o'clock. How do I fix this? Thank you.
Hi i owned a grand father clock and it had a reset button for the chimes BUT that was if it was an hour or two fast or slow It's only a guess because your clock is 1.15 slower than the chimes, You should be able to remove the hands off the face (note exactly where they were) and replace them 1.15 forward, NOTE you won't be able to push them 1.15 forward as the chimes will follow... I hope i haven't confused you... CHEERS..
Mar 14, 2016 | Office Equipment & Supplies
My Gazo GF Clock won't chime on hour at all
When you are setting your clock, when you go pass the hour you have to let the clock chime completely, if you do not do this you can damage the time sequence..You have to reset the chime cable or belt...but anytime you set your clock when you get to hour let it chime completely before continuing on...Try also going around with hour hand onetime and let it chime, if it will chime at all, if not you can get a manual download online. Clocks like yours has websites and support who can help you...I think it just needs the chimes reset.
Dec 17, 2014 | Home
Halo Grandfather Clock won't chime hour
In my eyes there are two kinds, ones that are a real grandfather clock that runs on gravity using a series of weights and gears with different counterweights for chimes and running the clock itself, and there are the show pieces that look like a grandfather clock but run on newer tech and electronics. If a real one then would try first pulling the weights to the top. They are usually shaped into a pinecone or something. If weight is at bottom them have to pull corresponding chain with weight till the weight is at the top of case. As "time" goes by the weights lower. You should have different counterweights for the clock, chimes, dancing figures and whatever else it may have. All the weights move at different "speeds" so you have to keep an eye on them to make sure it keeps correct time. I would recommend consulting the manufacturer if possible. There are so many kinds out there is really hard to tell by such a short video.
Dec 16, 2014 | Home
How to adjust Grandfather clock that chimes one chime less ?
Move the hour hand counter clock wise to 10 o'clock. Then turn the minute hand clock wise to set the correct time.
Main Page
Oct 04, 2014 | Home
Have a Galleria Grandfather clock thats chimes are off. How do I get them correct? Bought it at an auction and did not get any information with it. It chimed correctly in the beginning.
I suspect that the mechanism needs cleaning.
Take a look inside and if there is the slightest sign of dirt (particularly on the striking mechanism) then it should behave properly after cleaning.
May 01, 2010 | Watches
Need setting instructions for clock movement
Howard Miller offers this feature: This is how it works.
Automatic Night-Time Silencing Option
Grandfather Clocks will offer a night time shutoff option. There are 3 options on this lever.
1) "Night On" - This will keep the chime striking 24 hours
2) "Night Off" - This position will turn off the chiming between 10:15PM and 7:00AM
3) "Strike" - This position will allow the movement to strike the hour without the Westminster melody if the other Westminster melody lever is turned to Silent.
Hope this helps.
R/David
Apr 05, 2009 | Oregon Scientific Lwb0997110113004...
Grandfather clock not chimming
I can talk you through this Call me 407-309-3790 my name is David.
Mar 18, 2009 | Howard Miller Navionics Classic - Lake of...
Home Logo
370 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
