I think an inlet valve has a fault or has gone rusty inside becouse its worn
you should get someone in too fix it for you
or
you can tell which valve is faulty
usualy at the back there is a red hot water and a blue cold water
if you have both connected
turn off the red one under the sink and see if the water stops
try the blue next
if it stops then replace the valve
associated with the bad water intake
viola a fixed machine
two connections and two screws
you shouldnt use it just now incase the valve decides to open fully and stay open can reck your home
