Iriver Story HD vs Kindle
<br />
<a></a>
<span><span><span>The Kindle 3 was released by Amazon in 2010. It is available in two colors, graphite or white. iriver Story HD becomes first Google eBooks-integrated e-reader, developed by Google and iriver, which is similar to Kindle, but the buttons are copper-colored. Here we compared iriver Story HD vs Kindle from multiple specs.</span></span></span>
<br />
<span><span><span><br /></span></span></span>
<span><span><span>iriver Story HD vs Kindle: Supported Formats</span></span></span>
<span><span><span>Kindle supports eBook formats: AZW, TXT, MOBI and PRC.</span></span></span>
<span><span><span>iriver Story HD supports: PDF, EPUB, TXT, DOC, PPT, XLS, HWP, DJVU,GB2.</span></span></span>
<span><span><span>Note: sometimes conversion is need between different formats, </span></span></span><a href="http://www.drm-remove.com/resource/free-drm-remover.html"><span><span><span><span>drm free</span></span></span></span></a><span><span><span> is needed also. </span></span></span>
<span></span>
<span><span><span>So according to the differences between iriver Story HD and Kindle,did you make a decision to buy which? </span></span></span>
<span><span><span>iriver Story HD vs Kindle: Physical Features</span></span></span>
<span><span><span>The Kindle 3 weighs 8.7 ounces, and is 7.5 by 4.8 by 0.3 inches in. It has a 6-inch screen with 600 by 800 pixel resolution using Pearl E Inktechnology. It uses 4 GB of flash memory for storage.</span></span></span>
<span></span>
<span><span><span>The new iRiver eReader also boast a 6 inch XGA E Ink display with768×1024 pixels of resolution for a readable experience, 2GB of internalmemory, a 38 QWERTY keyboard with way controller for easy searching, USB 2.0port, wiFi and Lithium Polymer 1800 mAH battery provide read up to 140.000pages. In term of , the Google iRiver Story HD eReader measure in 128 x 9 x204 mm with weight 207 grams. (Related: </span></span></span><a href="http://www.drm-remove.com/resource/kindle-drm-remover.html"><span><span><span><span>remove kindle drm</span></span></span></span></a><span><span><span> , </span></span></span><a href="http://www.drm-remove.com/resource/remove-nook-drm-removal.html"><span><span><span><span>remove nook drm</span></span></span></span></a><span><span><span> )</span></span></span>
<span></span>
<span></span>
<span><span><span>iriver Story HD vs Kindle: Display</span></span></span>
<span><span><span>As you can see, whilst the devices look virtually identical in and shape, there is a slight difference in the actual displayed picture. Therepresentative that brought the piece of hardware also said that this iriverStory HD device will be the fastest refreshing e-reader on in the market currently.</span></span></span>
<span></span>
<span><span><span>iriver Story HD vs Kindle: Price</span></span></span>
<span><span><span>The iriver Story HD will cost $139, which is the same price as theKindle or the Nook.</span></span></span>
<span><span></span></span>
<span><span><span><span><br /></span></span></span></span>
<span><span><span>iriver Story HD vs Kindle: Connection</span></span></span>
<span><span><span>The Kindle 3 can be connected to your computer using its USB datacable or using WiFi through your home network. For purchasing books fromAmazon, the Kindle 3 uses the same 3G wireless networks. It takes less than aminute to download a book using 3G Wireless, with no cost to the user forwireless access. (related software: </span></span></span><a href="http://www.drm-remove.com/resource/remove-drm-from-ebook.html"><span><span><span><span>drm ebook removal</span></span></span></span></a><span><span><span> )</span></span></span>
<span></span>
<span><span><span>There's also WiFi - along with Easy Wi-Fi Network support for easierlogins at open hotspots, which means you can buy Google eBooks over Wi-Fi. </span></span></span>
<span></span>
<span></span>
