How do i connect Orion DVD Plaver to Old Model LG Televison with the use of remote controls.? I want to manual program a TV chanel to to watch movies! Regards Rajen
Turn both devices around, plug in their power cables and turn both devices on. Press the “Input” button on your television's remote control or on your television's front panel until “HDMI” or “HDMI 2,” or “AV” or “AV 2” or “Component” is displayed on its screen and you see the Orion logo transmitting from the DVD player.
1. Prepare three-color cable (or audio cable and HDMI cable).
2. Connect the audio line (three-color line) to the output interface of the left and right sound channels and the video interface.
3. If there are power amplifiers and audio speakers at home, use audio cable to connect to the second line of each output interface.
4. If it is a color difference TV, it is necessary to use a three-color line to connect the output port, and the DVD player that supports HDMI can be connected to the HDMI cable.
5. Turn on the DVD player and select AV mode with the remote control.
BTW, if you want to connect phone to TV, you can have a check at this two article for help.
https://www.leawo.org/tutorial/how-to-connect-iphone-to-samsung-smart-tv-1077.html?fixya=1410
How to Connect Phone to TV - Life Tips' Leawo Tutorial Center
The best option would be the HDMI-to-HDMI connection between your player and your TV. But because you mentioned that your TV is an old model, probably it does not have an HDMI port, in which case you have to use the RCA A/V connection. I understand you do not have a remote control for your TV, but you do not program a TV channel to watch DVD movies; you just switch between your TV and the DVD player as your audio/video sources. Here is what you have to do: check on your TV box for a button labeled 'Source' or 'Input'. Press on the button and it will alternate between TV and DVD (assuming you do not have any other device hooked up to your TV).
