Question about Toshiba 50HX81 50" Rear Projection Television
No picture Power is on but no picture. Power indicator light blinks rather than remain on.
Posted by mmestyer on
  • 1 more comment
  • Anonymous Nov 19, 2007
    i'm having problem with my toshiba 50h71 red light on front blinks and con't turn the tv on please help
  • xbox redneck Nov 29, 2007
    Same issue. I was playing Xbox and the TV clicked and the red power light flashes. Power button does nothing when I push it. When it is unpluged and plugged back in the tv power clicks and then click again and turns off with the red light flashing. The fuse by the power cord is still good. It has to be as easy as somthing is shorted out. I am not sure if I can take out the circuit board as it is the width of the TV. I found a service bulliten and it stated to look for a sodier joints that have broken loose.
  • papaL Dec 08, 2007
    I have the same problem - my Toshiba 50HX81 went off and will not turn on again... the red power light blinks unless the set is unplugged from the surge protector...
    I have checked the fuse - it is alright.... I have checked for loose wiring - found none... Any help appreciated.
Anonymous
I had the same issue, the blinking power light is a indicator...It cost me 400 bucks to have repair man fix.
Posted on Nov 15, 2007
No picture, no sound. Stand bye 4 red light blinks
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Jul 17, 2011 | Sony KP-53S70 53" Rear Projection...
Red standby light came on and no picture sound is ok .Next. time tv came on it played approx one hour everthing ok. then the picture gradually faded away . Red standby light came on again. Still no...
Jul 08, 2011 | Sony Televison & Video
Model# kf-50we620 no sound,no picture, red light blinking 3 time.and replace light bulb.
Jul 07, 2011 | Sony Grand WEGA KF-50WE620 Television
Standby light blinks 6X with no picture or sound
May 04, 2011 | Sony FD Trinitron WEGA KV-32HS500 32" TV
My Sony Trinitron TV 1999 (KV-32V42) made a strange popping sound and I lost both the sound & picture. When I turn it back on, the two red lights on the front of the TV(standby/Timer light & Stereo...
Feb 04, 2011 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Standby light blinks 7 times no picture
Jan 04, 2011 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Standby light keeps blinking with no picture
Dec 05, 2010 | Sony BRAVIA KDL-46V3000 Television
When I turn on my HL-T5687S, the screen remains black and there are 3 dots on the lower right hand side of the panel?
My TV is (same model is doing the same thing). The manual shows that the 3 blinking lights indicate "LED may be defective. Please contact a certified technician."
Note: When I power my TV off (unplug) and back on, the TV's left indicator light is solid for less than a second ("Stadby state") then the right light blinks ("The picture will automatically appear in about 15 seconds") for about 15 seconds. This pattern is repeated numerous times (I think it was 5 times). I believe the TV must be failing some power-on test. Aftere failing 5 times it gives LED may be defective indication.
Nov 09, 2010 | Samsung HL-T5687S Television
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Red power button & "lamp" indicator blinks
Having similar issue with my PT-44LCX65. Lamp blew and replaced it (last month), never figured out how to reset timer. Now red indicator light blinks once every 5 seconds and after about 4 minutes TV goes black.... Any ideas?
Dec 26, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Toshiba 50HX81 50" Rear Projection Television Logo
55 people viewed this question
Top Toshiba Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
