Question about Epson Stylus Photo R300 InkJet Printer
Reset counter on epson stylus R 300 photo printer
6ya staff
SOURCE:
Inky
Inky Fingers
  • 705 Answers
SOURCE: Epson Stylus Photo R320
Turn off the power and look inside the machine to the right hand side. Just in front to f the print head you will see a white plastic dowel (see photo). Use something technical - like a finger, pen or screwdriver - to push this dowel in. You can then move the print head by hand to the middle of the carriage.
Once moved, turn the printer on and watch it travel back to the home position. If after returning home the dowel pops back out and does not retract itself, you will need to strip the machine out and rebuild the ASF section. Sounds hard but its just a few plastic parts to take apart and reassemble whilst looking to see if anything is broken.
Get a service manual; for the machine HERE if you need to strip it out.
Posted on Sep 19, 2008
aayushik
Aayush khadka
  • 59 Answers
SOURCE: Epson Stylus Photo RX 560
if the waste ink cartridge ( which is called fuser ) is full then you have to replace it. thats what i do with my printers and copiers but i hvae never tried emptying thef fuser n use it again . you may wanna try that.
Posted on Nov 05, 2008
websnail
Martin Smallridge
  • 419 Answers
SOURCE: reset ink-pad counter on epson stylus photo 1400
The simplest way to do this is to grab a copy of the A10_IPR utility that Epson distribute to their customers...
The utility is available to North American customers if you register no this site page http://www.epson.com/ipr/
The utility is also know to be available in the wild if you search for "waste ink ipr".
Just remember to scan any download using a virus and malware scanner before you attempt to use it as some utilities contain trojans or similar nasties.
Hope that helps.
Posted on May 12, 2009
aicaxz
Anjazmoro Wicaksono
  • 511 Answers
SOURCE: epson stylus photo RX680 error message says;
Yes you're right. Use SSC service utility or RX680 Adjsument program. Find at indoreset.blogspot.com. Don't forget to replace waste ink pad, or just extend outlet pipe of head cleaning mech to outside.
Posted on Aug 28, 2009
ajitwahi
SOURCE: replaced ink cartridges in epson
general error normally comes if the printer carriage movement is obstructed
try doing the following
1 switch off the printer and switch on after some time and see that the head carriage moves properly or not if not than
2 look for obstruction in the carriage path
3 the cartiages installed might not be seated properly try reinstalling them
Posted on Jul 14, 2011
How do i reset ink pad counter on epson stylus photo px660
Try taking out all the cartridges and reinserting them.
Jan 24, 2014 | Epson Stylus Photo Px660
Tip
Manual Counter Reset Method
To manually reset the Ink Jet Counter that compels you to clean your waste pads. For the tip on how to clean your ink waste pads go here.
Please Note: In some cases, your printer may be leaking ink so much and so often that not only does your ink pads need cleaning, but you may need to replace the ink reservoir on your printer or you will have a leaking mess on your hands. This is a decision and judgment only you can make. If your printer is leaking quite of lot of ink, you may have to take it to an authorized Epson Repair Shop or Person. Find an authorized location by starting at Epson.com
The solution below is valid for most of the following printer models listed below this solution, some listed may not work, some not listed may also work it varies as this method is listed below is illegal for an authorized Epson Tech to release.
Thanks to the many user boards on the Internet for this solution that I know has worked for people I've helped here on FixYa.
Don't be discouraged if it doesn't work the first time. The key is in pressing the buttons exactly at the same time. So if this doesn't work the first time, try again and try again. Most people state they get it eventually.
[thanks to fixyourownprinter.com for the crux of this particular solution]
"Printer Onboard Control Panel Key Sequence"
"Press and hold the paper feed, paper switch and the power switch.
Once the power light and paper light flashes twice and the other lights are flashing release the paper feed and paper switch "and then press the paper feed switch".
The power, paper and ink lights will flash twice. At this point the protection counter has been reset."
Don't give up, if it does not reset the first time. The timing is tricky for some people.
Supported Epson Models that I am aware of, others not listed may work and some listed also may not work, it varies but don't be discouraged to try and try again.
You can also try the software download solution listed in this tip I posted.
Epson Stylus Сolor 400
Epson Stylus Сolor 440
Epson Stylus Color 480 LPT
Epson Stylus Color 480SXU / 580
Epson Stylus Сolor 600
Epson Stylus Сolor 640
Epson Stylus Сolor 660
Epson Stylus Сolor 670
Epson Stylus Color 680 / 777
Epson Stylus Сolor 740
Epson Stylus Сolor 760
Epson Stylus Сolor 800 / 850
Epson Stylus Сolor 860
Epson Stylus Color 880
Epson Stylus Color 900 / EM-900C
Epson Stylus Color 980
Epson Stylus Сolor 1160
Epson Stylus Color 1520
Epson Stylus Color 3000
Epson Stylus C20 / C40 / CL-750
Epson Stylus C41 / C42 / C43 / C44 / C45 / C46 / C47 / C48 **
Epson Stylus C50
Epson Stylus C60
Epson Stylus C61 / C62 **
Epson Stylus C63 / C64 **
Epson Stylus C65 / C66 and PE **
Epson Stylus C67 / C68 / D68 and PE **
Epson Stylus C70 **
Epson Stylus C80 **
Epson Stylus C82 **
Epson Stylus C83 / C84 **
Epson Stylus C85 / C86 and PE **
Epson Stylus C87 / C88 / D88 and PE **
Epson Stylus Photo RX420 / RX425 / RX430 **
Epson Stylus Photo RX500 / RX510**
Epson Stylus Photo RX520 **
Epson Stylus Photo RX600 / RX610 **
Epson Stylus Photo RX620 **
Epson Stylus Photo RX700 **
Epson Stylus CX3100 / CX3200 **
Epson Stylus CX3500 / CX3600 / CX3650 **
Epson Stylus CX3700 **
Epson Stylus CX3800 / CX3810 / DX3800 **
Epson Stylus CX4500 **
Epson Stylus CX4600 **
Epson Stylus CX4100 / CX4200 **
Epson Stylus CX4700 / CX4800 **
Epson Stylus DX4200 / DX4800 **
Epson Stylus CX5100 / CX5200 **
Epson Stylus CX5300 / CX5400 **
Epson Stylus CX6400 / CX6600 **
Epson Stylus CX6300 / CX6500 **
Epson Stylus CX7800 **
Epson PictureMate
Epson Stylus Photo
Epson Stylus Photo EX
Epson Stylus Photo 700 / IP-100
Epson Stylus Photo 750 / PM-770C
Epson Stylus Photo 780 / 790 / PM-780C
Epson Stylus Photo 810 / 820
Epson Stylus Photo 820 **
Epson Stylus Photo 825 / 915
Epson Stylus Photo 830 / 830U **
Epson Stylus Photo 870 / PM-875DC
Epson Stylus Photo R200 / R210 **
Epson Stylus Photo R220 / R230 **
Epson Stylus Photo R300 / R310 **
Epson Stylus Photo R320 **
Epson Stylus Photo R800 / PX-G900 **
Epson Stylus Photo R1800 **
Epson Stylus Photo R2400 **
Epson Stylus Photo 890
Epson Stylus Photo PM-890C
Epson Stylus Photo PM-A700 **
Epson Stylus Photo PM-G720 **
Epson Stylus Photo PM-970C **
Epson Stylus Photo 895/ 785EPX
Epson Stylus Photo 900 **
Epson Stylus Photo 925 / 935 **
Epson Stylus Photo 950 / 960 / PM-950C **
Epson Stylus Photo 1200 / PM-3000C
Epson Stylus Photo 1270 / PM-3300C
Epson Stylus Photo 1280 / PM-3500C
Epson Stylus Photo 1290
Epson Stylus Photo 2000P
Epson Stylus Photo 2100 **
Epson Stylus Photo 2200 / PM-4000EPX **
Epson Stylus Pro 5000 / PM-5000C
on Sep 17, 2008 | Epson RX620 All-In-One InkJet Photo...
Tip
Reset Epson Color Printer Counter
Many Epson Printers that reach an End of Life counter number will lock your printer down and force you to contact a Service Center.
However, this is really not necessary in all cases. If your printer is still working fine for you but the counter has locked your printer:
To download this free utility program read the agreement and then download.
Follow all instructions for download, install and usage.
End user agreement
1) This software is provided "as is" without any express or implied warranty of any kind including, without
limitation, warranties of merchantability, non-infringement or fitness for any particular purpose.
2) You are liable for all risks in relation to the quality or performance of this software. In no event shall SSC Localization Group or personally, author of this software, be liable for any damages whatsoever caused to you or the third party arising out of the use or inability to use this software. Damages include general damages, special damages, accidental damages or consequential damages (including, without limitation, loss of data or accuracy or unfitting interface for other programs, or problems with peripheral equipment).
2) You understand the risk of whole head or individual nozzles clogging in case of tardy replacing of empty cartridges, as well as risk of using hot swapping function (this include frequently cartridges replacement, or wrong deblocking of parking head on some models). You understand, that resetting the ink level counters or using ink freezer function implies responsibility to carefully watch ink levels in all cartridges and timely (as soon as You see any raw white bands, even in one color) replace cartridge.
I agree with all above statements and want to download software (v4.30)
Supported Models:
Model
Epson Stylus C50
Epson Stylus C60
Epson Stylus C70 **
Epson Stylus C80 **
Epson Stylus C82 **
Epson PictureMate
Epson Stylus Photo
on Aug 31, 2008 | Laser 3115cn All-In-One Printer
R 300 have three light blinking Red ink light, basic and advance light blinking green will not work
most probably the waste ink counter is full.. you will need to reset the waste counter and replace the porous pad..
Apr 03, 2011 | Epson Stylus Photo R300 InkJet Printer
I have epson stylus photo r230 printer. when i give print, the paper stops in the middle and centre red light start blinking
Hi!
I believe your waste ink pad counter registers that it is already full.
You may reset this counter by using the SSC Service Utility for Epson.
You may download it here: http://www.ssclg.com/epsone.shtml
Reset and Reboot.
Feb 14, 2011 | Epson STYLUS R230 InkJet Photo Printer
HOW TO RESET EPSON STYLUS PHOTO R230
Is it necessary to reset counter in Epson Stylus Photo R230x?
Jan 15, 2011 | Epson RX620 All-In-One InkJet Photo...
Epson 1390 service is required.
download free software resetter epson stylus photo 1390
Jan 10, 2011 | Office Equipment & Supplies
Reset ink-pad counter on epson stylus photo 1400
Hope that helps.
May 12, 2009 | Epson Stylus Photo 1400 Printer
Ink not empty
You have confused the software in either changing a cartridge when not required or having a chip failure whilst changing multiple cartridges.
Full info on how to get out of this is on my site.
Please go to my website http://www.the-inkstore.co.uk . I have the latest version of SSC Service Utility to download directly onto your computer and instructions on how to use it, what to click on etc etc. Click any of the Epson links if you can't find it, everything you need to know will be there, including printer Firmware resetting which sorts out a multitude of problems.
The 'maintenance required' problem with Epson printers has absolutely nothing to do with which cartridges you are using, it is a built in page counter in your printer firmware, which has a different maximum amount for each Epson model. Don't listen to old wives tales and heresay, we are the experts and it's an Epson scam to cause a lot of people to pay for maintenance or throw their printers away.
I haven't found a model that can't be reset with the latest version of SSC Serve or the manual reset on my site.
For Epson RX500 users there is also a manual reset on my site, as the SSC Serve software won't do it for you.
When using the program & choosing your printer from the list, it may have a weird name with 'x' in the model number, this is because some configurations are for many models in a series. For example, the C46 will be listed as C4x as it is for the C42, C44 & C46 models.
I hope this helps all Epson users to overcome the Epson scam of page counting and locking out until you pay their dealers money for maintenance.
If you like what I've done for Epson users, please show your appreciation by spreading the word and perhaps buying your ink from my site.
Happy trouble free printing
The INK Store (UK & Europe)
Apr 13, 2008 | Epson RX620 All-In-One InkJet Photo...
Epson Stylus Photo R300 InkJet Printer Logo
245 people viewed this question
Top Epson Office Equipment & Supplies Experts
Clive
Clive
Alun Cox
Thomas F. Schneider
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
