A diagram was sent to me by email but the pictures were too fuzzy to be helpful.
To replace a turntable drive belt.
Before starting any work on your turntable disconnect it from the mains power supply. Remove the stylus or complete headshell to prevent any accidental stylus damage.
1. Remove the rubber platter mat to expose the platter.
2. Put your thumb and forefinger through the two round holes either side of the centre spindle and lift the platter off. You may need to give the centre spindle a light tap (whilst applying upward pressure) with a screwdriver handle or some similar tool that will not leave any marks or damage.
3. Remove the old belt and wipe the platter and motor pulleys with an alcohol swab to remove any old belt residue.
4. Place the new belt around the platter pulley making sure it is sitting flat without any twists.
5. Flip platter over to the right way up. A correct fitting belt will stay put and an over sized belt will fall off.
6. You will see 1 or 2 large rectangle or square shaped cut outs in the platter near to the outer edge. Through one pinch up the belt and slip a finger or belt hook between the platter pulley and the belt gripping the belt ready to fit over the motor pulley.
7. Align the centre hole of the platter with the spindle and place platter back into position keeping a grip on the belt.
8. Slip belt over motor pulley and give the platter a light clockwise rotation to ensure the belt is riding correctly.
9. Replace the rubber mat and then run the turntable to ensure correct operation.
You have now successfully completed the process.
MUSIC IS LIFE, LIVE IT LOUD.
Copyright.. Styluscity, John Harrison.
SOURCE: Aiwa PX-E860 turntable
Don't understand. If it doesn't turn on, how do you know the electronics are ok? More than likely your transformer shorted, and will need to be replaced.
SOURCE: the drive belt on my Aiwa px-e860 turntable has
Lift felt on platter and and lift the platter section off the unit by putting your thumb and forefinger through the two large holes and pull upwards.There should not be any special routing for the belt and should go directly onto the spindle motor to your platter. Place the belt around the inside rim of the platter while it is still off the unit. Now replace the platter and move the platter around until you see the spindle motor through one of the holes. Use some tweezers to manouvre the belt onto the spindle motor. On some units you will have to lay the belt out inside the unit, replace the platter and manouvre the belt onto the platter. Hope this helps
SOURCE: Need to replace my AIWA
I have just fixed this problem on my Aiwa PX3800 with improvisation.
The platter was rotating too slowly, I didn't know how much too slow only that the records sounded wrong.
I imagined the belt, motor and platter as a bicycle gear and so simply increased the gear... I achieved this by winding a thin strip of a electrical insulation tape around the motor head to increase it's radius (like changing up to a larger front cog on a bicycle gear).
I could then time the rotations and remove a layer or two of the tape accordingly until I have achieved a perfect 45rpm. 33 is still way out but I only listen to 45s!
Be sure to trim excess tape from the motor head with a craft knife/scalpel or it'll stick to the platter.
Poor man fix up.
