Question about Sony BRAVIA KDL-40V3000 Television
Dark outline of Programme information banner at top of Screen fails to clear except on rare occasions.
Tried pressing i+ but does not remove the dark shaded area
Posted by Stuart Carter on
5 Related Answers
Anonymous
SOURCE: Dark Shaded Rectangle in the middle
I HAVE A SONY PFM-42B1. NO IMAGE, THE SCREEN DON'T TURN ON .STANDBY LIGHT BLINKING CONTINUOUS. I SELL THE TV FOR PARTS , MAKE ME AN OFFER. - Chicago Area -
E-MAIL: [email protected]
Posted on Feb 22, 2008
Anonymous
  • 541 Answers
SOURCE: I have a 10 to 12 inch dark area in the middle of
It sounds like a bad panel or possibly a bad digital board. This board is mounted on the back of the LCD panel. Have it checked by a repair shop.
Posted on Oct 14, 2009
Anonymous
SOURCE: when I turn on my kdl-46xbr5 sony tv in the
Goto http://esupport.sony.com/US/perl/news-item.pl?news_id=378&template_id=1
Posted on Mar 19, 2010
eagle338
eagle338
  • 4889 Answers
SOURCE: Sony KLV-S32A10 LCD TV background
You either have a malfunctioning LCD controller(T-con) or the panel itself is faulty. The T-con is very inesxpensive and easy to replace but the panel is gonna cost you nearly as much as a new tv. Let me know if you want to give the t-con a shot so that I can guide you to fix it.
Posted on Dec 06, 2010
e-Guru
e-Guru
  • 3917 Answers
SOURCE: When I first turn on the set, part of the screen
Hi
It could be a power supply problem or an inverter board problem or something internal having to do with the backlighting of the unit. remove the inverter, and look at the back side and you will see a hot spot, now on the other side of that hot spot, re-solder the service mounted components and that should take care of your problem.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Jan 05, 2011
Highlander DVD player has line down screen
I am not familiar with this but I presume you refer to a portable type car unit which I see on the web.
Is this line a twinkle type line or a clean dark line?
Both will tend to be a player fault which may not be able to be fixed (in todays chuck it out world).
If its a solid clean dark line then this may be a display screen fault which laptops etc can get, the only cure change its display panel (often pricey so not worth it)
Then again if this a twinkle white type line, to me this a component failure (capacitor) which there many inside whose job is to remove noises. A service is required if possible with that company (could be costly if an older unit) or sadly "live with it" as it mostly will only spoil enjoyment rather than create a serious issue.
It can be on a disc but I presume you have tried others anyway (rare anyway, except if you record your own discs then it can be your recorder putting it on) again rare.
Hope this helps................
Jun 04, 2016 | Televison & Video
Ok Iam afraid my question was misunderstood. I have a 70 inch mitsubishi projection TV. it doesn't have color outline or 3D imiging. It has a dark section about 6inches from the top down that is dark not...
I would take it in and have it devices professionally. It may just be dusty inside, however having a pro do it is best. Use warranty if applicable.
Aug 29, 2014 | Televison & Video
Spots on the display screen
Still not clear, what you mean. But take care wham cleaning a lens. Never use a fluid like alcohol. Use a special lens pen or the soft brush on the other side of a lens pen, when you think the lens is dirty. Spots, or disk, also can appear when light is entering the lens from an angle. Even the expensive Fuji X10, had orbs or disks on the pictures in certain situations. Like dark with one or a few sharp lights close bye. Try the camera in different situations, to make sure the phenomena is in the camera or just a strange rare occasion.
When it is caused by a defect in the camera, it should show on every picture.
Dec 26, 2013 | Vtech Kidizoom Digital Camera
Screen is dark
Jan 24, 2013 | Computers & Internet
My wife's presario cq60 widescreen laptop has a power problem. For a period of time now, several weeks, on occasion it will simply go dark and nothing lights up. I remove the battery and power cord...
By go dark do you mean it turns off? If not, LED lights on the front of the laptop continue to stay on, but the screen goes dark, this could mean the backlight of the screen is going bad. It might be intermittent, but, a screen consists of two elements, the display itself, and the backlight which is what makes the image bright. If you bring it into a well lit area when it is dark and tilt the screen back and forth, you might see the faint image on the screen. Sadly, screen repairs are expensive, easily exceeding $300 most of the time. It is often a better idea to replace it rather than repair it.
Aug 24, 2011 | Compaq Presario CQ60-220US PC Laptop
My brightness control does not work just turned on and can not hardly see anything it is up and running what now
Have you tested it with an external monitor?
I would say you either have a damaged inverter board or screen baclight lamp. Usually the inverter board fails in one of the following ways:
1. When you turn on the laptop, the screen lights up for a short period of time and then goes dark. You still can see an image but it is very dark, almost invisible and definitely not usable. When you restart the laptop, the screen lights up and then goes dark again. The laptop works fine with an external monitor.
2. Your laptop turns on but the screen remains dark all the time. You still can see a very dim image outline. The laptop works fine with an external monitor.
3. The laptop screen works fine for hours or even days, but sometimes it goes very dark as it mentioned above. When you restart the laptop, the screen works fine again.
Inverter failure symptoms are very similar to backlight lamp failure symptoms and in most cases you cannot tell which one is causing the problem until you replace either the inverter board or the backlight lamp. From my personal experience, inverter boards fail more often than backlight lamps. If you have to guess, replace the inverter first.
Mar 24, 2010 | Dell Inspiron 1545 Notebook
Background "halo light effect" when using XR-10-XL in 16x9 mode
Do you mean there is a dark grey outline when using it in 16x9 mode? This happens with my projector too. Try using dark (or black) masking around the screen.
Aug 20, 2009 | Sharp XR-10X Multimedia Projector
Image through nikon f80 dark and cloudy
I'm unfamiliar with the F80 but on models like the f65 and f75 the viewfinder screen has an lcd overlay and when the battery is exhausted or removed the viewfinder goes dark and blurry.
Looking at a picture of the f80 it looks like it's just an update on my f75 so it strongly suggests that you just need to insert a fresh battery. The lcd does draw power from the battery even with the camera turned off.
I hope that you found my answer useful, once you've tried another battery to confirm what I've suggested I'd appreciate it if you return the favour by rating my answer.
Jul 20, 2009 | Nikon F801S 35mm Film Camera
Sony BRAVIA KDL-40V3000 Television Logo
47 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
