Question about Yamaha Audio Players & Recorders
I have a yamaha receiver rx-v371 the speaker imput clamps on the back are broken. Can i use banana plugs?
Posted by Amanda Frederickson on
Scott Frye
    Genius:
  • 1,175 Answers
For the main speakers , Yes, you can use banana plugs. Theyre built for that.
I hope that helps
Posted on Dec 16, 2014
Yamaha Receiver RX-V371 broken speaker wiring connection on the back, what are different solutions?
That unit give you the option for a second set of speakers ?
If so , connect to Output 2 ( or B) on the speakers connections and select Spkr 2 ( or B) from the front panel
Dec 16, 2014 | Yamaha Audio Players & Recorders
How to connect my JBL JRX 115 speaker to my Yamaha RX V673 receiver
You would use a standard banana plug to either a 1/4 phono or speakon plug. The JBL JRX 115 has both on the back. All the outputs on the Yamaha RX V673 have banana plugs. The channel you plug into would be up to you, there are many choices and they are listed on the back of the unit.
Dec 03, 2013 | JBL Audio Players & Recorders
HAVE A YAMAHA RX-V371 RECEIVER, NO CABLE BOX AND I CANT GET ANY SOUND FROM MY PHILLIPS HDTV.
if you have a coax digital out on your tv, why not use that, you have coax, optical, and hdmi inputs on your reciever, but the easiest, low cost way is the coax
Feb 20, 2013 | Yamaha RX-V371 A/V Receiver
Yamaha rx-v371 shuts off 2 secs after turning on
Return unit to place of purchase, this is clearly a manufacture defect. The warranty will cover full replacement, do not allow them to attempt repair on the current item because you will be back and forth until warranty runs out.
Apr 02, 2012 | Audio Players & Recorders
My Yamaha RX-V563 receiver displays "Check Speaker
Look closely at the rear connector panel of the receiver and look for pieces of stray strand wire that may be touching the speaker A binding post and the receiver chassis. If you are not using strand wire connection to the binding post then check whatever connector type you are using such as banana plug or spade plug for breakage or corrosion, the same goes for the speaker cable itself which isn't always so easy to detect. A few broken strands can cause a problem.
If it is clean, turn off the receiver and disconnect the speaker cable. Check the binding post for tightness; if you can wiggle it then it is broken and needs to be replaced.
Oct 03, 2011 | Yamaha RX-V563 Receiver
Just clicks no power. Already checked for touching wires and proper cooling. This unit has worked fin in the same location for four years. Any other ideas?
I had a similar 'drop out' problem with my Yamaha RX-V3300.
Problem- Possibly loose speaker connections.
I have banana connections which I unplugged; tightened speaker terminal connections at back of receiver and then reinserted banana speaker connectors- which remedied problem. There is possibly some kind of loose connection either caused by the banana plugs or at speaker connectors at the back of the receiver, which was remedied (i.e. possibly temporarily) by reinserting the banana plugs.
I also previously thought something was wrong with the main on/off power relay which was 'dropping out' and replaced it, but then 'drop out' problem returned a few days later. I reinserted and tightened speaker connectors, which has it working again.
Dec 22, 2009 | Yamaha RX-V630 Receiver
96 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Will
Level 1 Expert
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
