I changed power pack also the power jack but nothing....i was told power jack is wrong one, while another tells me its the correct one....thanks
SOURCE: Sub Woofer does not work
hi there are fast checkings for you: Quick Connect Card http://www.alteclansing.com/downloads/641QCC.pdf manual: http://www.alteclansing.com/downloads/641_MAN.pdf is the system working fine exept the sub? my guess: the headphone jack works fine then the speakears are too if soo then the sub amp is bad or some connection is torn try opening the sub and see if everything is hooked right and if soo then the amp is the problem every electronics shop can fix this good luck
SOURCE: Any info on Altec Lansing Satellite 31 set up?
Hi, I have these. Always unplug the Sub before changing the wiring around.
You should have a dual cable. Plug one end into the Sub's Audio In and DC Out (the one that looks like a power plug goes in DC Out, the one that looks like a headphone goes in Audio In). The other end of the dual cable goes to the Satellite that has the volume control. Plug into DC and Sub. Plug a cable with headphone plugs on each end into the SPKR jack on each Satellite. Plug another cable with headphone plugs into either Input 1 or Input 2. The other end goes to your computer's audio out. I don't have the original of these two cables so I can't tell you what they look like. If one is longer or thicker it should be the one to go between the speakers. Set the level control on the Sub about 1/4 up. Plug the Sub in and play some music. You can adjust the Sub level and the Bass and Treble to your liking. I have my Bass & Treble straight up, Sub at 1/4. You can use one of the inputs for your computer and the other input for another device like an iPod without having to unplug things.
SOURCE: Altec Lansing ada885
Same issue showed up for me today very randomly...
HD comes on and off for no reason and sound cuts in and out. This fix worked for me:
1.Disconnect the left speaker from the sub woofer.
2.Take the 4 screws out on the bottom of the left speaker. (They are under the rubber matting you can just poke holes through it)
3. Remove the bottom plastic assembly from the speaker
4. Cut the 4 wires to the headset chip. Careful not to cut any others to the speakers themselves!
5. Unscrew and remove headset plug chip
6. Reassemble and plug left speaker back into sub woofer.
No more HD issues =)
SOURCE: Altec Lansing ATP3 volume control/power know gone bad
just sone it, i had to break a whole in the bottom part , work my way around it with a screwdriver , it will snap every 2-3 cm and come off in the end.
after its off start at the (now exposed) bottom of the front bit and work your way up and aroud `till it comes off. mind the wires . as for the volume button fix , as soon as i played with it and tried it again , everything was good. even though replacing it doesn`t seem like a big deal
put it back together and will superglue it in the future( while typing this i doubt if it will ever happen), and it lookes good( except from the bottom ,where its broken !).
now the button is solid and the sound as well.
SWEET
SWEET
SOURCE: Finding replacement Power Supply for Altec Lansing
Hi Yeo...
Amazon offers pretty much power supply products, click on this link Finally charging for our multi device world and choose your model.
I hope this was helpful.
enjoy
