To unlock the password on your LG Cosmos, you need to re-program your phone. This will default the code to the last four digits of you cell phone number.
You First need to temporarily activate the ESN (also known as MEID, HEX) off the back of your phone underneath the battery to you Verizon Wireless cell account.
You can change the ESN (Electronic Serial number) as follows:
1.) Verizonwireless.com
2.) Dialing *228 opt. 1 from the phone you want to activate, while the current activated phone is off
3.) by calling customer service to temporarily activate the phone (1-800-922-0204 or *611 from a Verizon Wireless handset not involved.
(note: most all phones, even if their locked should still be able to call 911 and the programming number (*228)
You can activate the phone for a day to an existing account just to do this if necessary.
Once you change the ESN on to a phone number and program it
Dial *228 on your phone, listen in and pick option 1 for programming.
after listening to music for about a minute or two you should hear "programming completed successfully"
Once you hear this you can hang up the call. The phone should reboot by itself.
If not power it down manually and then power it right back up.
now you should be able to unlock the phone with the last four digits of you cell phone number you chose to activate it too.
SOURCE: MY SON LOCKED LG VX5200
you are going to have to find the last 4 digits of your phone number, because that is the unlock code.
If you dont have a way of finding it, maybe you could try moving the SIM card into another cellular phone of the same provider and calling from that.
Hope it helped.
- Josh
SOURCE: LG VX4500 Cell Phone and need to unlock
Call customer service, they will give you a code to unlock it
SOURCE: password & phone number problems
Have you tried going to your service store? They will give you a code to unlock your phone.
SOURCE: I WANT TO LOCK MY FOLDERS AND FOR THIS I HAVE TO
look the default **** code you have to create first or it may be 000000 or you try 00000
SOURCE: forgot the phone code for my cosmos the phone is
It should be the last four digits of your cell phone number. If that doesn't work, try four zeros. Hope this helps!
