Question about GE Profile Spectra JGBP90 Gas Kitchen Range
I have tried pushing the clear/off button. I turned on the oven yesterday, not using the probe, and the probe light kept flashing. I pushed the clear/off button several times and it stopped. Today I came home from work and the "probe" and "bake" lights are flashing simultaneously. I tried pushing the clear/off button several times. It went off for a few seconds and came back on. I pushed the probe button then the clear button. Both come right back on. What are a few more things I can try?
SOURCE: no heat at burners or oven
check your fuse / breaker box make sure you have power (sounds like you dropped a leg of power) make sure breakers/fuse is on/good flip it to off the to on if oven don't work then take a look at the cord to the range check power at the wall then open where cord goes into range check power or you may even find the cord burnt in there if so replace all damaged wires good luck
Posted on Dec 22, 2007
SOURCE: oven AND broiler do not work but self-clean does
good day, i suggest to check all inside wiring and switch. thanks
Posted on Mar 06, 2008
SOURCE: GE JGB920 Gas Range problem
if not post your email i will send you the service manual
Posted on Mar 15, 2008
SOURCE: Probe and Bake blink alternately.
I had the same problem. I resolved it yesterday. Detailed instructions can be found if you access my inquiry under the user name bhmlton. If you can't find them, then let me know and I'll get them to you another way.
Posted on Sep 23, 2008
SOURCE: bake button doesn't work even after ignitor replaced
While unlikely, the ignitor in theory could have damaged the ERC (main oven control) it is more likely you have a bad keypad. Try pressing and holding bake and broil pads at the same time for 5 seconds and see if the display shows SF (will look like 5F). If it does, press the start button and try again bake again
Posted on Dec 18, 2008
