Taking the power wire that goes into the timer and the power wire that comes out of the timer and put them together not hooked to the timer and that should work. If that works you should solder them together and electrical tape them good.
I would suggest the wrong wires were cut off and joined. If the ground wire touches the power wire a fuse or circuit breaker will blow.. Before you do anything more make sure the curcuit breaker is not blown. If it is reset it and turn the cooker back on. If the breaker blows again then it is wired wrong.
Testimonial: "Quick response & very helpful, thank you"
Thanks for the answer Dan, is apperciated. Are you able to tell us which wires he SHOULD have cut? Our wiring is old so no circuit breaker apparently, so must be a fuse blown somewhere, perhaps in the cooker plug itself??
I am not sure but usually the power cord in and out of the cooker should be the same color. Also I just thought. To find out if the plug receptical in the wall is working plug a lamp or something else in it and if the fuse is blown the light will not work. Make sure if you have to replace a fuse you use the same amperage that you take out.
When I say power in and power out cord colors I am talking about the wires that are on the swutch its self. not the color of the whole main cord. Most power cords are black and the ground is white in appliances.
