Question about Dell A940 All-In-One InkJet Printer
Error message 50c on printer
I have the Dell A940 printer and it keeps giving me error message 50c. I have unplugged the usb cable and power cables and then re-plugged them back in. I have restarted the computer, but it still refuses to print and keeps giving me the error message 50c. What can I do???
Posted by strobeone on
  • 9 more comments
  • linehand Nov 13, 2007
    Error message 50c dell printer problem
  • strobeone Nov 13, 2007
    I tried it before, but this time added the "old" and now we are back in business. Thanks so much!!!! Chris
  • pestoface Feb 26, 2008
    I've done everything I could possibly do with the printer including wiping out the whole underbelly where the cartridges are. I've done everything the dell user manuel recommended, there's nothing at all there or at Dell's site. I was printing photo's with a new refilled color cartridge when this error appeared. I took the new cartridge out and put the old one back in just to be safe. I've reinstalled the printer, disconnected cables I'm at my wits end, can you help? Dennis
  • driver24 Jul 16, 2008
    Same problem here. Error message 50c. Cannot resolve.
  • Anonymous Jul 20, 2008
    I have the same problem, same error message 50c, I have already removed and replaced both original cartridges and selected old and its still only prints blank
  • micliz19 Jul 30, 2008
    I continue getting the error message - I have tried all the steps but don't get the message "new or old" on the LCD.
  • rayj123 Sep 24, 2008
    I have tried all the solutions that I can find for the 50c error problem on my A940 printer with no success. Is there some thing else?
  • jazzgal43 Dec 18, 2008
    I also have the Dell A940 printer and it keeps giving me error message 50c. I have unplugged the usb cable and power cables and then re-plugged them back in. I have restarted the computer, but it still refuses to print and keeps giving me the error message 50c. It stopped doing this for a day or two, then started again. It had been printing very light and sometimes refusing to print at all intermittently. Now it is back to error message 50c and not working at all. I have taken out both ink cartridges and re-installed them several times. What can I do? Is my printer "dead?"
  • jmmeyer2 Dec 26, 2008
    when installing the cartridges I get error message 50C. I uninstall and reinstall but still get the same error message.
  • Anonymous Apr 20, 2009
    Error message 50c : I have tried everything from new cartridges to no cartridges, and the error continues. I have cleaned the contacts on both cartridge and printer. Even reloaded program. Help!!
  • Kuchipudi Apr 28, 2009
    I am getting the Error No 50C on my Dell printer A940 model. Can any one help me to handle this problem?
Anonymous
I had the same error message 50c and "color Ink low". I knew that I still had Black Ink, and that is what I just needed for the moment, so I removed the color Ink cartridge and it started working. You'll get a message 'print cartridge missing' but just press continue.
Hope this helps,
MPTMPeru
Posted on Apr 08, 2009
Thomas Christopher
    Genius:
  • 1,601 Answers
  1. Make sure the printer is turned on.
  2. Lift the printer's front cover.
Error message 50c on printer - note.gif NOTE: The ink cartridge should be in the up/loading position unless the printer is busy.
  1. Squeeze the tabs on the cartridge lids and lift the cartridge lids up. The cartridge pops up when the lid is fully lifted.
  2. Remove the cartridges.
  3. Check and make sure that all of the protective tape has been removed from the contacts on the ink cartridge.
  4. Replace the cartridges.
  5. Snap the lids closed.
  6. Close the printer's front cover.
  7. When prompted on the printer's LCD to choose New or Old, choose Old.
  8. Press the Select button.
This was from Dell's website
Posted on Nov 13, 2007
Anonymous
Selecting "Old" fixed the prblem for me in only a few seconds.
Posted on Sep 13, 2008
What is Cartridge Error 50C?
Error message 50C in the Dell A940 All-in-one means that the ink cartridge(s) are seated improperly.
Here are basic steps to try that should resolve the issue:
1. Reseat the Ink Cartridges.
2. Unplug the printer from the back, clean the contacts and the put back the connection.
3. Verify whether the Ink Cartridges are DELL Branded.
4. Try Cartridges Individually.
Jan 22, 2011 | Dell A940 All-In-One InkJet Printer
Dell A940 prints black but doesn't print in color. I installed a new color cartrige and the 50c error went away, but still doesn't print in color...
Hi there Error 50c
This is for yours.
Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
You may have to buy a new cartrige.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Nov 20, 2009 | Dell A940 All-In-One InkJet Printer
Getting error, "cartridge error" 50C. Dell All-in-one printer, model A940
Hi there Error 50c
Yes this allways happens.
color cartridge.
Oct 13, 2009 | Dell A940 All-In-One InkJet Printer
Printer will not print it will say error 50c
Hi there Error 50c
Ok try this.
color cartridge.
Sep 18, 2009 | Dell A940 All-In-One InkJet Printer
Can't find "cartridge error 50C" in my Dell owner's manual
Cartridge Error 50C
Your print cartridge has shorted.
  1. Power off your All-in-One and unplug it.
  2. Plug in your All-in-One again and turn it on.
  3. Uninstall and then reinstall your cartridges.
  4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Cartridge Error
Complete the following instructions:
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges.
Aug 13, 2009 | Dell A940 All-In-One InkJet Printer
My A940 All-in-One shows a Cartridge error 50C and also shows that the colour cartridge is missing when it is not can you please help tried looking through manual but cannot find what a 50C error is please...
Hi there Error 50c
All the best of luck
color cartridge.
Jun 17, 2009 | Dell A940 All-In-One InkJet Printer
Not printing. shows error 50C
Cartridge Error 50C
Jun 13, 2009 | Dell A940 All-In-One InkJet Printer
I am receiving cartridge error - 50C. I have
Hi there Error 50c
This happens a lot in dell printers.
color cartridge.
Mar 31, 2009 | Dell A940 All-In-One InkJet Printer
DELLA 940 DOES NOT PRINT
Hi there Error 50c
color cartridge.
Jul 20, 2008 | Dell A940 All-In-One InkJet Printer
Dell A940 All-In-One InkJet Printer Logo
2,674 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Richard C Cohen
Richard C Cohen
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
